1 members (klhansen), 101 guests, and 1 robot.
Topics128,151
Posts1,056,999
Members48,460
Apprentice
Apprentice
Finally tore in to the front brakes, sandblasted/painted the backing plates, got new shoes, wheel cylinders, and had the drums turned down. Unfortunately this is the first time I've taken a close look at the suspension and it looks like my kingpins have too much slop, my tie rod is all bent up, and the leaf springs almost arc the other way. Also the bearings are worn so I'll probably be replacing those with new roller bearings. So, more parts on order and around $500.00 later I should have just about a brand new front suspension by the time I'm done. Feels good to get back in the garage though!
brake before
brake after 1
brake after 2
drums
kingpin
Your doing a nice job. Do It Once....Do It Right.
Keep us posted.
EDIT: I like the video. Nice.
That looks good! I agree - as Achipmunk said - "Do It Once....Do It Right." Just an observation - it looks like the hold down clips are sandblasted but not painted - you may want to paint those also so that they don't rust. Nice job!
Samantha
1954 Chevy 3100
Picked from the Field
Follow in the DITY
Hi, keep in mind that if You find a spring shop where You live they can make new springs and its alot cheaper than ordering and paying shiping same with the king pins NAPA has them , tie rods too. They order them but You do not pay any shipping, Pete
A spring shop can also re-arch your old springs.
