7 members (jal12147, F100Ranger, NJC, Bruce 1954-4100, Bill Hanlon, Hotrod Lincoln, 1 invisible),
111
Mod | | | Forums66 Topics128,087 Posts1,056,338 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 8 New Guy | | New Guy Joined: Jun 2006 Posts: 8 | Looking for information on 1949 chevy sedan delivery. Roof has a seam in the center from front to back. Is this supposed to be welded or did the factory use a seam sealer? Any iformation would be helpful. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ....seam in the center?? Well, I'm waiting for replys on this. Why would there be a seam in the center??? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | there was no factory seam in any sedan delivery roof ... earlier there was a large wood-fabric area in the center, but once they got the ability to make one piece stampings that big, it was one piece, joined to the pillars at all 4 corners with welded and leaded joints, same as the panel bodied trucks .... 39 sd top - very large pic, see if you find evidence of a seam  Bill | | | | | Joined: Jun 2006 Posts: 8 New Guy | | New Guy Joined: Jun 2006 Posts: 8 | I have a 51 suburban which has no seam, we took it down to bare metal. This sedan delivery has a seam directly in the center from front to back with the roof being all metal. A fried who is working on it is considering welding it. | | | | | Joined: Apr 2008 Posts: 17 New Guy | | New Guy Joined: Apr 2008 Posts: 17 | I would call Chesser Auto Emporium in Lawrenceville, GA. Mike has had several sedan delivery's down to metal. | | | | | Joined: Jun 2006 Posts: 8 New Guy | | New Guy Joined: Jun 2006 Posts: 8 | Thanks for the information. I will give Mike a call. | | | | | Joined: Apr 2006 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 62 | You people are confusing the sedan delivery with a panel/suburban truck. The sedan delivery was build on a car frame, and yes there was a welded seam down the center of the roof. I don't beleive any manufacturer had the capability of stamping out a piece of metal that large. Don't forget there was no drip mold and so the panel had to go from beltline over the roof area and down the other side to the beltline.These vehicles were a low volume build so it was done the easiest way possible. (I worked for the General in tooling for 37 years) Stan Norrish | | |
