0 members (), 143 guests, and 6 robots.
Topics128,077
Posts1,056,033
Members48,433
#516028 03/12/2009 2:01 AM
Splitting off from another forklift thread...
Originally Posted by Grigg
I too just picked up a forklift, quite handy. Traded it even for a walk in cooler, mine looks to be a mid 90's Komatsu with a Nissan 4 cylinder overhead valve regular gas engine. It's also rated to pick 6,000 lb. Still need to find a manual, and curious what year it really is.
Originally Posted by 48bigtrucks
Grigg,
Do you have pictures of that Nissan/Datsun engine? I suspect it's an "E" engine which is a great engine. Let me know if you need and "help" with it, I've turned wrenches for Nissan for 22 years. I actually just replaced a headgasket on one of those a week or so ago, brought back memories of the early days, LOL,
Scott
The lift is a model FG30HT-12 Type G
Serial #501422A
Can't find anything meaningful on the engine other than Nissan
If it's an "E 1600" engine, those parts could be had from an 83-87 Sentra/Pulsar. If it's an "A" engine you would need to look at a 210/B210/510 type of car. Might even be a NAP "Z" 2400 engine too. Shoot me a picture, they're easy to distinguish from one another,
Scott
Here are some pictures of it, starting with this one:
http://rides.webshots.com/photo/2430125920080251109cunKRt
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
Grigg #516081 03/12/2009 3:57 AM
That's an "A" motor which is a push rod engine. I believe a 210 model Datsun would get you the parts you need. That's a decent little engine but a little prone to blowing head gaskets. Easy to work on though,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Thanks Scott,
I'll try that.
What leads to head gasket problems, over heating, or??
I won't be working it very hard or long, so I'm not expecting any or much trouble out of it, but if there is something I need to watch out for it'd be good to know ahead of time.
Grigg
Grigg #516177 03/12/2009 2:49 PM
Age and the corrosion that occurs between cast iron and aluminum are the main contributors to the head gasket failures. They will start using anti-freeze and miss a little bit cold when they start to go. There's usually plenty of warning time,
Scott
Scott Ward
1 1950 3100
1 1963 K20 (454)
1 1964 C10 (350)
I called Komatsu lifts today trying to find somewhere to get parts.
From the serial number they said it is a 1997 model, and has a Nissan H25 engine. They even knew it has dual front tires.
They also said I can install air filled or foam filled tires that will get around the gravel lot a little better than the slick hard tires it has now.
Grigg
---All pictures---
Grigg #520277 03/24/2009 4:08 AM
I kinda looked around the internet a bit looking at Nissan powered lifts and found a lot of suppliers out there. They seem very popular so finding parts should be easy for you.
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
Moderated by  MNSmith
