Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
7 members (thekid1950, Rusty Rod, cmayna, baldeagle, tclederman, Oswald, carbking), 45 guests, and 1 robot.
Topics128,006
Posts1,055,268
Members48,418
#51381 10/20/2005 3:27 AM
I am new to old chevys. I bought a 63 last month and i am looking at a 62 for parts. I want to find out what engine is in the 62. Is there any good book recomendations for a beginner such as me? thanks.
I see a GM truck in your future!
#51382 10/20/2005 3:48 AM
welcome to the garage rusty - the 62 was the last year for the 235 as the standard 6, so it might be that - less likely it would be a 261 - 63's had 230's or 292's, but they really all interchange
for books, try the list here under links>publications - lots of possibles for a newbie, like Gunnell's and Brownell's general history books - also might get the shop manual for your year, available from most repro parts dealers
#51383 10/20/2005 4:03 AM
The 62 and the 63 have a lot of differences that might trip you up. It depends on what you need from it. The engines won't swap, the front suspensions are of two totally different designs, the hood and grill are different too. Body wise, most of the sheet metal and glass will interchange. Good luck with your projects and it's good to see someone from (sort of) my neck of the woods joining in. Welcome,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#51384 10/21/2005 3:15 AM
thanks to you both for your reply(S). It is a 2 ton truck and the block looks bigger than mine so Im guessing its the 261. It is always good to communicate with like interested people especially in the land of rust.
#51385 10/21/2005 3:32 AM
a 2 ton would be a bigger engine, but if the block looks bigger, it may be a 292 - the 235 and 261 look very similar, 292 is longer - numbers from block might ID it
