| | | Forums66 Topics128,087 Posts1,055,974 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I had planned on using a Lokar petal and linkage but after reading the directions you can get on line I believe I might do better with a stock set-up from a 70s/80s vehicle. Has anyone had experience with this kind of petal for their ride?
~Jim
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | BIG,
I used the complete pedal and linkage out of a '76 Nova. This was on a pickup with a 350/350 combo. It worked great and as I recall, was easy to install. There is a bracket with a punched square hole that mounts on the carburetor hold down bolts. This is where the plastic sheath of the wire throttle linkage goes as well as the tranny kickdown linkage. The gas pedal bolted to the firewall quite easily.
Stuart | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | GREAT! Sometimes I feel like I'm checking my trot-line here. Sometimes I find a nice perch, sometimes I find a shad. Can you post some pictures of how you set yours up? Or send me an email. Thanks
~Jim
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | I used the Lokar peddle / cable on my 327 with Edelbrock carb. Easy install, clean look, comes with mounting brackets for carb. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I used the Lokar peddle / cable on my 327 with Edelbrock carb. Easy install, clean look, comes with mounting brackets for carb. What was the stock number?
~Jim
| | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | 3600,
Look on any mid '70s (give or take) Chevy "C" series. The only difference between the pedal assemblies for the 6cyls and V8s is the length of the cable! It is a hanging style pedal that comes out with just two screws for the whole assembly! Get the carb bracket too, even id just to use as a pattern or modify. What I did was to measure the height of the pedal bottom in the stock location so I would know how high to mount the pivot on my firewall. It is so easy it'll amaze you. Get the newest one you can. The pivot block is some kind of plastic and does wear.
best wishes,
Les | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I also used a mid 70's (78 I think) cable and pedal. I used the one that has three self-tapping screws and screwed it right to the firewall. I had to bent and tweak the pedal rod some to get it just right, but nothing serious. I then drilled a hole in the firewall right behind the upper part of the pedal rod for the cable. I filed it square and until the cable snapped into it securely and attached the other end to the carb. I think it took me longer to type this that to actually do it, Scott | | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | 3600, Sorry for any confusion. Here's the story of salvaging the '75 Chevy parts from a wrecked truck. http://www.stovebolt.com/features/feature_stories/parker/index.htmlScott has it dead on the head! The "C" Note+ for the Lokar stuff can be better spent in many other places on your truck. best wishes, Les | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | 3600 - Not sure of stock #. This is a standard, universal unit from their cataloge. Mounts on firewall. Can order matching pedals for brake & hi-beam switch as well | | | | | Joined: May 2005 Posts: 96 Shop Shark | | Shop Shark Joined: May 2005 Posts: 96 | Hi,
Same question for a 1946 chevy-pickup with a V8
Jan | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | I use the cable off a Ford. It has the return spring as an integral part of the cable so no separate bracket and return spring are needed. It also uses a round hole in the firewall which is easier than making the square one for a GM cable.
Evan
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Here's the gas pedal I used. I can't remember what make it is. I bought it at a swap meet 2 years ago! The throttle cable was a universal 'cut to fit' Spectre unit bought from Autozone. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
