3 members (David Bush, 52Carl, Jon G), 136 guests, and 13 robots.
Topics128,078
Posts1,056,029
Members48,433
#513662 03/05/2009 11:01 PM
I had planned on using a Lokar petal and linkage but after reading the directions you can get on line I believe I might do better with a stock set-up from a 70s/80s vehicle. Has anyone had experience with this kind of petal for their ride?
~Jim
BIG,
I used the complete pedal and linkage out of a '76 Nova. This was on a pickup with a 350/350 combo. It worked great and as I recall, was easy to install. There is a bracket with a punched square hole that mounts on the carburetor hold down bolts. This is where the plastic sheath of the wire throttle linkage goes as well as the tranny kickdown linkage. The gas pedal bolted to the firewall quite easily.
Stuart
GREAT! Sometimes I feel like I'm checking my trot-line here. Sometimes I find a nice perch, sometimes I find a shad. thumbs_up
Can you post some pictures of how you set yours up? Or send me an email.
~Jim
I used the Lokar peddle / cable on my 327 with Edelbrock carb. Easy install, clean look, comes with mounting brackets for carb.
1940 Chevy KC 1/2-Ton
What was the stock number?
~Jim
3600,
Look on any mid '70s (give or take) Chevy "C" series. The only difference between the pedal assemblies for the 6cyls and V8s is the length of the cable! It is a hanging style pedal that comes out with just two screws for the whole assembly! Get the carb bracket too, even id just to use as a pattern or modify. What I did was to measure the height of the pedal bottom in the stock location so I would know how high to mount the pivot on my firewall. It is so easy it'll amaze you. Get the newest one you can. The pivot block is some kind of plastic and does wear.
best wishes,
Les
I also used a mid 70's (78 I think) cable and pedal. I used the one that has three self-tapping screws and screwed it right to the firewall. I had to bent and tweak the pedal rod some to get it just right, but nothing serious. I then drilled a hole in the firewall right behind the upper part of the pedal rod for the cable. I filed it square and until the cable snapped into it securely and attached the other end to the carb. I think it took me longer to type this that to actually do it,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
3600,
Sorry for any confusion. Here's the story of salvaging the '75 Chevy parts from a wrecked truck.
http://www.stovebolt.com/features/feature_stories/parker/index.html
Scott has it dead on the head! The "C" Note+ for the Lokar stuff can be better spent in many other places on your truck.
best wishes,
Les
3600 - Not sure of stock #. This is a standard, universal unit from their cataloge. Mounts on firewall. Can order matching pedals for brake & hi-beam switch as well
Hi,
Same question for a 1946 chevy-pickup with a V8
Jan
Don't waste water, drink wine !
1946 Chevrolet 1/2-Ton Truck
I use the cable off a Ford. It has the return spring as an integral part of the cable so no separate bracket and return spring are needed. It also uses a round hole in the firewall which is easier than making the square one for a GM cable.
Evan
Here's the gas pedal I used.
I can't remember what make it is. I bought it at a swap meet 2 years ago!
The throttle cable was a universal 'cut to fit' Spectre unit bought from Autozone.
More pix on Flickr.
