7 members (stlcardinalsguy, Maybellene, Wally / Montana, Wheelie, Otto Skorzeny, Gdads51, MarkT),
188
Mod | | | Forums66 Topics128,078 Posts1,056,022 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#51336 10/19/2005 4:23 PM | Joined: Sep 2004 Posts: 19 New Guy | | New Guy Joined: Sep 2004 Posts: 19 | 6 months ago I bought new 16 inch tires for my 40 1/2 ton. Now I am going to change out the rear end for a 52 powerglide to get a better gear ratio. The 52 has 5 hole 15" wheels and I want to keep my new 16" tires and wheels. There is not enough material on the axle flange to redrill the larger 6 hole pattern. Does anyone have a better idea? I know I could buy yet another rear end from a 48 or older car but I am trying to avoid the expense and the work of doing that. Thanks for any help. Dale | | |
#51337 10/19/2005 4:47 PM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I know this has been done but suspect that you;ll need to first weld up the 5 holes and then redrill. | | |
#51338 10/19/2005 6:03 PM | Joined: Sep 2004 Posts: 19 New Guy | | New Guy Joined: Sep 2004 Posts: 19 | The bolt circle on the axle is 4 3/4" and the 6 hole circle I want is 5 1/2". The axle flange is only 6 1/8" wide. That only leaves 1/16" of material outside of the bolt hole. I called Moser Engineering and they said redrilling was not possible. I suppose they may be concerned about product liability and I wonder if it would work if I could find a machine shop to do it. Dale | | |
#51339 10/19/2005 6:06 PM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | some say it is not a good idea to re-drill but I dont know............Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#51340 10/19/2005 6:20 PM | Joined: May 2005 Posts: 314 Shop Shark | | Shop Shark Joined: May 2005 Posts: 314 | Provided that your rims are properly fit to the hub, the lugs only hold the rim to the axle. All of the radial load is on the hub. There is no radial force against the lugs. Therefore, I can see no reason why re-drilling would be a problem. | | |
