1 members (klhansen), 147 guests, and 0 robots.
Topics128,162
Posts1,056,939
Members48,458
what seat would be best to use in my 48 chevy truck or would it be best to redo the original. Also how can you make in expensive custom door panels.
You can put in other seats with modifications. Is your truck stock or hotrod ? If stock I would redo it. I have seen bucket seats in them from a Mazda truck they work ok. Door panels get some panel board from ypur local upholster and cut to fit and cover. Tom
I'm using bucket seats from a late model chevy silverado in mine.
Robert C.
I'm a Genius in the making.
1950 3600
A 88-98 full size Chevy bench seat fits right in. We used flat stock and bent it into an S for each side to give it lift and then an inverted V from the center of the seat to each side to give it lateral stability. Top edge of the seat comes just below the back glass and has openings for seat belts. Width is nearly perfect.
Just here for the free beer.
1953 1-Ton Dump Truck
1954 Teenage Hot Rod
i have 2000 Buick lesabre seats because i wanted shoulder belts and didn't want to weld the attachment points. 2000 and up will work. a little tight if you are long legged or over 6 feet tall. look in my photobucket for pix. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
I second the buick seat.
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
if your trying to go with a bench seat setup but want to go modern i am planing on using S-10 bench seats in my 39 its not much thicker than the original seat and will fit nicely over my tank "which on the 39 is under the seat"
1937 1/2 ton
Moderated by  ndkid275, Phak1
