0 members (), 160 guests, and 5 robots.
Topics128,149
Posts1,056,818
Members48,456
#51153 10/14/2005 9:29 PM
Junior Member
Junior Member
I see a lot of guys like the s-10 4x4 rear ends.
I have a 1951 chevy with a 53 235. what year s-10 should i be looking for? What are the gear ratios? what about hub bolt pattern? will my stock steel rims fit. I really want to keep my stock rims. How do i tell if it is posi or not?Any info would help. Or should i just look for 55-6-7 rear end as originally planned. thanks.
#51154 10/14/2005 9:43 PM
mine has a 85 blazer and s-10 five speed.this keeps the 6-lug pattern, I believe that your options narrows some if you want to keep the six lug,, your gear options are also various, I have a 2.73 in mine and it works ok, if you do any hauling , your might you want a 3 something, more folks will probably chime in, good luck with your choice...welcome to the bolt.........Fred
Redryder pix
My Hotrod
#51155 10/14/2005 10:03 PM
i have a 54/235 with fentons and dual carbs and exhaust with a 1979 nova witha 2.73 and a t-5 trans. i am well satisfied with setup. i live in the flat land indiana. it does well off the line in the first 4 gears and 5th gear well on small hills. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
#51156 10/14/2005 10:36 PM
With the S10 trucks, the 2wd rears are 4 inches narrower than the 4wd / AWD rears. Many were 3.42 & 3.08, but some 4cyl trucks had 3.73s.
Get the wider.
MV
46 Chev One Ton Panel - S10 Frame Project
"What if the Hokey-Pokey is REALLY what it's all about?" - J. Buffet
#51157 10/15/2005 2:25 AM
Junior Member
Junior Member
Can anyone list the different S-10 rear end widths
#51159 10/16/2005 6:22 AM
the 1998 and up s-10 s blazers envoys and brovitas and jimmies all had rear disk on the 4x4
ya I know a few rednecks.Thay all drive chevys to,
Proud member of the Old Dominion Stovebolt Society
AND A MARINE
trucks range from 1942 1/2 ton to 1965 fire engine
#51160 10/16/2005 4:51 PM
If you have access to a 55-6-7 rear you can keep your 6 lug and will most likely have a 3.90 ratio. This will work well with a S10 T-5 trans because the od will give about a 3.08 final ratio and through the gears you'll have plenty of pulling power for hills.
