0 members (),
100
Mod | | | Forums66 Topics128,157 Posts1,056,875 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 46 | what seat would be best to use in my 48 chevy truck or would it be best to redo the original. Also how can you make in expensive custom door panels. | | | | | Joined: Oct 2008 Posts: 22 New Guy | | New Guy Joined: Oct 2008 Posts: 22 | You can put in other seats with modifications. Is your truck stock or hotrod ? If stock I would redo it. I have seen bucket seats in them from a Mazda truck they work ok. Door panels get some panel board from ypur local upholster and cut to fit and cover. Tom | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | I'm using bucket seats from a late model chevy silverado in mine.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Apr 2000 Posts: 199 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 199 | A 88-98 full size Chevy bench seat fits right in. We used flat stock and bent it into an S for each side to give it lift and then an inverted V from the center of the seat to each side to give it lateral stability. Top edge of the seat comes just below the back glass and has openings for seat belts. Width is nearly perfect.
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | i have 2000 Buick lesabre seats because i wanted shoulder belts and didn't want to weld the attachment points. 2000 and up will work. a little tight if you are long legged or over 6 feet tall. look in my photobucket for pix. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | | | | | | Joined: Nov 2008 Posts: 355 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 355 | if your trying to go with a bench seat setup but want to go modern i am planing on using S-10 bench seats in my 39 its not much thicker than the original seat and will fit nicely over my tank "which on the 39 is under the seat"
1937 1/2 ton
