4 members (Rich'sToys, gswbbc, Hanks custodian, 1 invisible), 129 guests, and 1 robot.
Topics128,047
Posts1,055,538
Members48,424
I have carpet in my 37 now but want to put a rubber flor mat in it,does anyone know if the are being reproduced and are there insulation available for the firewalls too. Jeff
Jeff-
I have looked high and low and have never found any pre-made rubber floor mats for our trucks. I finally bought some heavy duty rubber and made my own. You can see it in the pictures of my truck on my web site. I think it looks pretty good. As far as insulation, most everyone I know has used the foil insulation with the bubbles between the foil layers on each side. It's light weight, easy to cut to fit and seems to work pretty well. I have it all down my firewall (inside) and under the floor mat.
Apprentice
Apprentice
Joe,
The rubber that you used, what was it originally used for? Where did you get it and about how much did it cost? Thanks!
Dale
Dale -
I buy it locally at an upholstery place. They carry several types of rubber matting for floor mats, trunk mats and running boards. I think it's about $10.00 a foot.
Joe
V
V Offline
I went to the junkyard and cut the rubber mat from the cargo area of a work van.
It was about 4'x8', big enough to make a full mat for my Apache and a 4x4 mat for our front door. It was $15. I had to scrub it, and it's not super pretty, but I plan on having dirty feet a lot when I get in my truck anyway.
1959 3200 Apache Fleetside
In the Legacy Gallery
I am using black ribbed rubber that I bought at an industrial supply company. I would prefer to have the ribs running fore and aft but its not wide enough. Although having the ribs run sideways it makes it easier to whisk clean.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
just as more info I bought a rubber mat that has the "measles" look and used the "jute" original type backing. Since the 37 is basically flat it worked pretty good. What ever you use take your time to cut and fit and you'll have a nice job.
"back then" I think I got it from American Classic..or Jcarter.
Moderated by  ndkid275, Phak1
