1 members (Hotrod Lincoln),
41
0
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#50675 09/28/2005 10:03 PM | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | Okay, so I'm halfway through a front-end rebuild: I've dismantled it. That means I'm half done, right? Anyway, the tie rod, a tubular type with screw-in ends, has a slight bend. I can see about 1/2 of the opening at the far end when I look through. The bend is gentle, no kinks. Is replacement a priority, or can it be used still? I'm not sure where I would get a new one, although I got the ends off the rack at NAPA.
Thanks, Guys and Gals
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
#50676 09/28/2005 10:21 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Highflyer, Many people get nervous when it comes to steering items...If it were mine, I wouldn't hesitate to straighten it. The tie rod is very tough and can take a ticken and keep on , whatever! Do it cold..use a vise, a barn door or whatever. Don't kink it or make a pretzel out of it and you will be fine. Don't forget to set the toe-in again.
Stuart. | | |
#50677 09/28/2005 10:34 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Someone probably got a jack under it at one time. You can straigten it like Stuart says. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#50678 09/28/2005 10:59 PM | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | I personally would not take a chance with straightening it, and they are available from CD for like $30, and those are a lot stronger than the original. I had the same problem, and am very happy with the CD replacement. | | |
#50679 09/28/2005 11:23 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Brian, Are you saying they are making a tie rod in 2005 for 30 dollars that is stronger than one made in 1949? I'll bet the new one isn't made on this continent... Stuart. | | |
#50680 09/29/2005 3:47 AM | Joined: Aug 2004 Posts: 90 Member | | Member Joined: Aug 2004 Posts: 90 | We just talked about replacement a little bit... I just bought two of those for $22.00 each that's cheap. NOS - wwII metal. see bruce bugay a stovebolter, vintage chevy club 11211 woodstock hgts, glen allen, va. 23059 804 752-6063 http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=2;t=009883;p=1#000000 chevyb Member Stovebolter # 2634 posted 08-24-2005 08:32 PM -------------------------------------------------------------------------------- I have some of those tie rod ends ES29 R+L new. $22 ea. [email protected] -------------------------------------------------------------------------------- Posts: 93 | Registered: Jul 2002 | IP: Logged |
Gooday Jim
small wheel moves by fire and rod, big wheel fires by the grace of god, everytime that wheel turns round, bound to cover just a little more ground.
#50681 09/30/2005 11:30 PM | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | Yes, the repro one is better than the original. One of the very few times when this is true. | | |
#50682 10/03/2005 2:57 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Brian, Maybe, because it is a "critical" steering component, it had to be up to snuff. Thanks for the info! Stuart. | | |
