5 members (Woogeroo, Wally / Montana, MickeyP, Lostbuthaulinass, 1 invisible), 120 guests, and 3 robots.
Topics128,050
Posts1,055,753
#50675 09/28/2005 10:03 PM
Okay, so I'm halfway through a front-end rebuild: I've dismantled it. That means I'm half done, right? Anyway, the tie rod, a tubular type with screw-in ends, has a slight bend. I can see about 1/2 of the opening at the far end when I look through. The bend is gentle, no kinks. Is replacement a priority, or can it be used still? I'm not sure where I would get a new one, although I got the ends off the rack at NAPA.
Thanks, Guys and Gals
#50676 09/28/2005 10:21 PM
Highflyer,
Many people get nervous when it comes to steering items...If it were mine, I wouldn't hesitate to straighten it. The tie rod is very tough and can take a ticken and keep on , whatever! Do it cold..use a vise, a barn door or whatever. Don't kink it or make a pretzel out of it and you will be fine. Don't forget to set the toe-in again.
Stuart.
#50677 09/28/2005 10:34 PM
Riding in the Passing Lane
Someone probably got a jack under it at one time. You can straigten it like Stuart says.
1972 Chevy c10 Cheyenne Super
#50678 09/28/2005 10:59 PM
I personally would not take a chance with straightening it, and they are available from CD for like $30, and those are a lot stronger than the original. I had the same problem, and am very happy with the CD replacement.
#50679 09/28/2005 11:23 PM
Brian,
Are you saying they are making a tie rod in 2005 for 30 dollars that is stronger than one made in 1949? I'll bet the new one isn't made on this continent... wink
Stuart.
#50680 09/29/2005 3:47 AM
We just talked about replacement a little bit...
I just bought two of those for $22.00 each that's cheap. NOS - wwII metal.
see bruce bugay a stovebolter, vintage chevy club 11211 woodstock hgts, glen allen, va. 23059 804 752-6063
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=2;t=009883;p=1#000000
chevyb
Stovebolter # 2634
posted 08-24-2005 08:32 PM
I have some of those tie rod ends ES29 R+L new. $22 ea. [email protected]
Posts: 93 | Registered: Jul 2002 | IP: Logged |
Gooday
Jim
small wheel moves by fire and rod,
big wheel fires by the grace of god,
everytime that wheel turns round,
bound to cover just a little more ground.
#50681 09/30/2005 11:30 PM
Yes, the repro one is better than the original. One of the very few times when this is true.
#50682 10/03/2005 2:57 PM
Brian,
Maybe, because it is a "critical" steering component, it had to be up to snuff. Thanks for the info! smile
Stuart.
