0 members (),
93
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 145 | I'm trying to remove the lug bolts on the rear of a 53 1/2 ton. I have some bolts that have bad threads. The first few came out easily with hitting with a hammer. But the others won't budge. I've even tried heating it with mapp gas and still not luck. any suggestions? In the Gallery[yrl=http://viewmorepics.myspace.com/index.cfm?fuseaction=user.viewPicture&friendID=43825635&albumId=1717519]More pictures in MySpace[/url]
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Really big breaker bar with a bigger piece of steel pipe. Then stand on it.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | start by tightening - use a good impact wrench
Bill | | | | | Joined: Nov 2008 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 145 | I'm talking about the lug bolts. not the lug nuts. In the Gallery[yrl=http://viewmorepics.myspace.com/index.cfm?fuseaction=user.viewPicture&friendID=43825635&albumId=1717519]More pictures in MySpace[/url]
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Bigger hammer. And if that doesn't work, use an air hammer.
Bill Burmeister | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | ah, the studs  different ball game, they'll be very tight in the axle flange, might hafta take it to a shop with a press, don't think I'd be heating that axle much Bill | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I have drilled out a few. I think that they must have flared them out on both ends.
I was real careful not to drill into the spindle. I started with a small bit and gradually got larger. Then I took a hammer and chisel.
Best of luck
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Those bolts (studs) are not threaded, they have raised, straight "ribs" like these) . This handy tool set can be used to both remove the old studs and install the new studs, with the axle still on the truck. No hammer is necessary - you will be pressing the stud out and then in. | | | | | Joined: Nov 2008 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 145 | 2 of them will not come out. I think they might be rusted in there. I'll probably have to just leave those two without nuts until it is drivable, and I can take it to the shop and let them give it a try. In the Gallery[yrl=http://viewmorepics.myspace.com/index.cfm?fuseaction=user.viewPicture&friendID=43825635&albumId=1717519]More pictures in MySpace[/url]
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | If you cant beat them back with a 5# fist maul, then the best bet is to cut them off flat, then start step drilling from the center. When you get close to the knurled portion, a 5# fist maul and a large drift.
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | oh yeah, and dont hit yourself
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Had a couple just like your describing. I sprayed with penetrating oil and soaked them and soaked them. Nothing doing. Finally I had to grind them flat as mentioned above, then center punched and drilled them out. The steel is not that tough and with a couple nice sharp bits they will come out. The Knurled edges (ribs) is what makes it tight and holds it in. After drilling them out the new ones are sort of tough to pull all the way in. Good luck. | | | | | Joined: Nov 2008 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 145 | That is where I am at right now. The bolts are grade 5 i'm guessing. I got a hole drilled in the 2 that won't budge, but as I go bigger in size, the bolt just won't cut. The smaller bits where able to go through with a lot of force, but the larger ones with the more surface area are a little tougher. I ordered the little handy press that tclederman recommended and I'll give that a try. In the Gallery[yrl=http://viewmorepics.myspace.com/index.cfm?fuseaction=user.viewPicture&friendID=43825635&albumId=1717519]More pictures in MySpace[/url]
| | | | | Joined: Jul 2006 Posts: 451 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 451 | I have yet to find anything that I cannot remove that is stuck with the old PB blaster and heat. I got this trick off this site and I am a burnin coolin fool. Heat it with a propane torch. When it is good and hot, spray it with PB blaster. Then apply the proper tool(s)to remove, i.e. BFH and drift pin, wrench, vise grips, etc. On lugs bolts I like to put the lug nut on to provide me with more surface area when swinging the "meat". The experts here say heat expands the metal breaking rust and corrosion. When sprayed the PB is drawn in as it cools. I removed a pitman arm the other day via this method. Put the puller on it with tension, heated, cooled with blaster, it popped, and I proceeded to wrench it off. I have removed broken bolts in nuts, nuts on bolts, you name it. Heck, I'm contemplating using it to see if it will get the ex off my [censored]! Cavebull | | | | | Joined: Aug 2008 Posts: 230 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 230 | in the machine shop we used to swage the top of the knurled portion sticking out of the Axel ,look to see if it was swaged ,most stock one's on 5he old stuff was . we used a cutter to cut the swage off to keep from enlarging the bore . | | | | | Joined: Sep 2002 Posts: 159 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 159 | I saturated mine in PB Blaster, lightly tapped them w/ a hammer straight on to shake free rust, and put the lugs nut on and use it to back them out
56 stepside 3/4 ton longbed
| | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | This maybe a little late, and there is a big difference between a 53 and a 68. I recently had to knock the studs out to replace the drums on the rear of my 68 C20. I left the lug nut at the top of the stud. The I used two 2# mallets placing one on top of the lug nut and hitting it with the other. This gives you a larger area to hit, which allows you to think about force rather than aim. It also adds 2# to the down force. Another 2 cents gone.  Larry
I don't own a vehicle that isn't old enough to drink. | | |
