10 members (TexasJim50, Jay R, TUTS 59, Hotrod Lincoln, Forty9, cmayna, Lostbuthaulinass, Woogeroo, Peggy M, 1 invisible),
89
Mod | | | Forums66 Topics128,134 Posts1,056,411 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2002 Posts: 99 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2002 Posts: 99 | Swiss Cheese The interior front portion of my cab roof is riddled with little rust holes. How would you recommend patching that? Weld in a new panel or new sheet metal? Fiberglass? Marglass? Bondo? My truck is going to be a driver and will have some plastic filler on it so I'm not requiring that everything be patched with metal. At the same time I don't want to cut corners and want my work to last for many years. What would you suggest?
Neil 1955 Chevy 3200
| | | | | Joined: Dec 2004 Posts: 425 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 425 | Looks like it's just on the interior piece? For a daily driver it wouldn't hurt to use fiberglass filler, assuming you are going to sand it down and finish it nice. | | | | | Joined: Oct 2002 Posts: 99 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2002 Posts: 99 | Yes, it is just the interior piece - the actual roof is in really good condition. It appears some mice made nests in between the two pieces of metal and trapped moisture which caused it to rust out. However I fix it I will be making sure it is smooth and painted nicely.
| | | | | Joined: Jan 2007 Posts: 615 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 615 | I have that on my 55 3600. The way I fix those is to "dimple" each hole so the hole edges are rolled inward. This creates more surface area for the filler to hold on to without building it up high. I fill with fiberglass paste...the type that has ground glass in it ..not fiber. I then sand that and then cover the whole area with bondo..fo the cosmetic repair.
Of course if your gifted at fabbing sheet metal and welding it in that would be great but since your asking this question I sense you don't want to do that....It's a bad place to open up a can of worms.
Best of luck,
Keith | | | | | Joined: Dec 2006 Posts: 443 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 443 | I had the same rodent problem on my 57. I cut the header out and found a real mess. I started with this and had to buy this to put on here so I would end up with a good roof . I never had very good results in the past trying to cover rust with filler or fiberglass. 1957 Chevrolet 1/2-ton Stepside LB in the Gallery My Photobucket shots The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873) | | | | | Joined: Nov 2005 Posts: 144 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 144 | Hey Alan,
Where did you find the spare roof? I've got to do the same thing to my 56.
Thanks, Zeke
PS: If someone ever started making replacement panels for this area they would make a killing!
| | | | | Joined: Dec 2006 Posts: 443 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 443 | Hey Alan,
Thanks, Zeke
PS: If someone ever started making replacement panels for this area they would make a killing! I got mine from JIMBO59CHEVY here on Stovebolt in the PARTS forum. He has a lot of TF stuff & has always been very fair with me. When you get ready to do the replacement let me know. I can give you a few pointers after doing mine. You can buy a new repro roof and the inner header, but the inner is over $300 & the outer over $350 plus shipping. I'd go with the used parts. 1957 Chevrolet 1/2-ton Stepside LB in the Gallery My Photobucket shots The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873) | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I had to replace the roof on my 63 too. That's a reinforcing piece and I would cut it out and replace it. You can replace it with a home made piece as long as it was solid, it doesn't have to look like the old one. Also, a bigbolt's roof will work too, Scott
