3 members (2-Ton, kbenz, MNSmith),
161
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,108 Posts1,056,238 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | No.s next to distributor on block are FI2ISJC. ON cylinder head they are 3836848 GM16 | | | | | Joined: Feb 2000 Posts: 5,216 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,216 | | | | | | Joined: Mar 2006 Posts: 319 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 319 | The 235 head, 3836848, was used at least 56'-60' I believe.
F121(S),(probably a 5)JC decodes as a Flint engine built on Dec 15. The engine serial number suffix 'JC' appears in a 58' and 59' list of GM engine suffixes and was a Thriftmaster "235" with 3 speed transmission.
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
| | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | this engine right now is in a 1960 k-20 so i was trying to figure out if it was the original engine and if it was a 235 | | | | | Joined: Jan 2008 Posts: 360 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 360 | the 848 head was also used to replace the stock heads on 261 motors for a simple inexpensive increase in compression. does appear to be a 235 though. if it is an early 60 truck it may be original, if that is the question.
"it's only old if you can't find a use for it; otherwise it's cool and i'll use it."
| | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | yes trying to figure out if it is original engine and if in fact it is a 235 block and head . does any 1 know for certain of size of engine . do i need to get other no.s off block to tell | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Look for the block casting number on side of block. Also look for "Captains Bars". It is possible that you have a 261 which were available for the K20 then with an 848 head. Block casting numbers would really help ID it.
Drew
| | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | where are the block casting no.s located | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | thanks for info on location | | | | | Joined: Jun 2006 Posts: 75 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 75 | I am trying to find alot of info on my 327 I picked up. the numbers on it are CE 4N23608 and S0117XCB. aby help please.
"you can't fix stupid"
| | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | no.s on block are 3769716 and b48848850 | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 3769716 is the block casting code for a 58-62 235 truck engine.
Where on the block did you find b48848850? Was the location as shown at photo #4 at the link above? If so, that code is a mystery?
| | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | i dont remember exact loation of b488488850 was near distributor. can i assume this to be original engine | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | It looks like an engine that could have used in a '59 or '60 truck. Did you check the head and block date casting codes (locations are shown at the link I posted above).
A late 1959 engine (block and/or head) could have been originally installed in a 1960 truck.
| | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | 235 Block casting 3769716 (could also be listed as 3739716):
Truck - 1960-62 Mech. Cam, Front Center Mount Passenger - 1958-62 Std. & P.G. Trans, Hyd. Cam
The 261 engine 1960-62 is block casting 3769717
-Tom
1950 Chevy 3100 w/ 1956 235
| | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | Thanks everybody for the information much appreciated.I am starting the restoration of my truck and am almost ready for the engine, transmission, transfer case to be sent to be rebuilt. | | |
