0 members (),
149
Mod | | | Forums66 Topics128,113 Posts1,056,619 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Valve cover looks like a F@#*.
~Jim
| | | | | Joined: Feb 2004 Posts: 29,836 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,836 | Are the motor mounts straight across from each other? If so, it could be a 194, a 230, or a 250. If the right side mount is offset toward the rear, it's a 292. Jerry
| | | | | Joined: Jan 2009 Posts: 6 New Guy | | New Guy Joined: Jan 2009 Posts: 6 | Motor mount is behind the fuel pump, so it's not a 292.
Thanks for the replies guys!
49 3100 52 3600 5 window 68 K20
| | | | | Joined: Nov 2005 Posts: 266 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 266 | That is a later HEI distributor that you have, its from a late 70's to mid 80's truck. The side covers rule out it being a 292. You're off to a good start not having the integral head on there.
Big Chevy, I think my grandfather's '84 C-10 has a valve cover like that one, and it has a 250 in it. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | All I could find was that it's a 1966 through 1985 250CID. Maybe someone with a newer book could decipher the stamped code, Scott | | | | | Joined: Apr 2000 Posts: 499 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 499 | My book says the 348675 # is for '66-'79 250. The HEI is the external coil type used in '75-76. The hole on the top-front of the valve cover is the oil fill hole. The one on the side should have a large tube that goes up to the air cleaner. This is the fresh air inlet for the PCV system. The PCV valve is already in place at the rear of the valve cover with the vacuum hooked up to it.
'67 GMC 3/4 292 4spd
| | | | | Joined: Jan 2009 Posts: 6 New Guy | | New Guy Joined: Jan 2009 Posts: 6 | Thanks a lot guys, you have gotten me a lot closer than my hrs of research had gotten me! The 5 in the date code could nail it to 75 if your HEI theory is correct and the HEI is not a transplant.
| | | | | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 |
| | | | | Joined: Jan 2009 Posts: 6 New Guy | | New Guy Joined: Jan 2009 Posts: 6 | Thanks Chuck! I had already poked around your site before but without any kind of mid point to start with this engine, I was having a hard time nailing it. I pulled the distributor hold down and got the rest readable, it has served to only confuse the issue more....... F0322CCT I am unable to come up with a CCT at this point. http://www.badassmustangs.com/gallery/albums/userpics/10038/IMG_0193.jpg
| | | | | Joined: Feb 2000 Posts: 5,228 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,228 | You are looking at the serial number, that won't help identify it much. You need date codes, pull valve cover and check the date code of the head. At this point, it won't mater anyway, we are almost 100% sure its a 250. All parts for a 250 will interchange through the years and you have the best head going.
| | | | | Joined: Jan 2009 Posts: 6 New Guy | | New Guy Joined: Jan 2009 Posts: 6 | Perfect, I will just roll with it from there! Thanks everyone for helping.
| | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | GM block casting 348675 is an Oldsmobile 250.
-Tom
1950 Chevy 3100 w/ 1956 235
| | | | | Joined: Jan 2009 Posts: 6 New Guy | | New Guy Joined: Jan 2009 Posts: 6 | Well that kinda throws a wrinkle in the works, but I guess it doesn't really change anything??
