2 members (Otto Skorzeny, 5 Window 9434), 130 guests, and 4 robots.
Topics128,266
Posts1,058,385
Members48,485
You guys and gals that do exhaust at home, are you welding the pipe all around the muffler, or just tacking it? I want to replace the muffler on my car, and the old one is just tacked in place. I'm wondering if thats wrong. Should I tack it, then pull it down and weld all around it? I suspect mine is tacked, as the shop that did it 25 years ago didn't want to mess with all those rusty nuts, and neither do I really .
Thanks for your input.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
if you don't weld it all the way it's likely to leak - you could always use a clamp instead, that's common, especially with replacements - either way will rot in our climate, but neither necessarily lasts longer
I have had good luck welding all the way around than spraying high heat paint on it when cooled off.
I clamp the mufflers with Riker band clamps that way I can easily remove the muffler and replace 2-3 times before the pipes rust out.
I have only welded one exhaust system and the muffler rusted out and I had cutting and welding rusty exhaust.
Scott, Thats something I hadn't really thought of. I picked up the glass pack and clamps. The pipes that are on the car are 1 3/4. I suspect they've been there for a while! That does explain the high exhaust velocity at the rear of the car. I'm going to clamp it, as some day I'm thinking of splitting the exhaust, but thats a long way down the road.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1926 Model TT Truck
I like them welded all the way around myself.
ooh good info,
Hadn't thought about the replacement issue,and with a truck sitting ,that does tend to rot the muffler.
Maybe I should the race car trick with springs holding the pipes together.
just-a-hacker
'49 3100 before '99
