2 members (delky, Sjm),
120
Mod | | | Forums66 Topics128,266 Posts1,058,385 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | You guys and gals that do exhaust at home, are you welding the pipe all around the muffler, or just tacking it? I want to replace the muffler on my car, and the old one is just tacked in place. I'm wondering if thats wrong. Should I tack it, then pull it down and weld all around it? I suspect mine is tacked, as the shop that did it 25 years ago didn't want to mess with all those rusty nuts, and neither do I really .
Thanks for your input.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if you don't weld it all the way it's likely to leak - you could always use a clamp instead, that's common, especially with replacements - either way will rot in our climate, but neither necessarily lasts longer
Bill | | | | | Joined: Jan 2009 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 47 | I have had good luck welding all the way around than spraying high heat paint on it when cooled off. | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | I clamp the mufflers with Riker band clamps that way I can easily remove the muffler and replace 2-3 times before the pipes rust out.
I have only welded one exhaust system and the muffler rusted out and I had cutting and welding rusty exhaust.
| | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Scott, Thats something I hadn't really thought of. I picked up the glass pack and clamps. The pipes that are on the car are 1 3/4. I suspect they've been there for a while! That does explain the high exhaust velocity at the rear of the car. I'm going to clamp it, as some day I'm thinking of splitting the exhaust, but thats a long way down the road. | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | I like them welded all the way around myself. | | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | ooh good info,
Hadn't thought about the replacement issue,and with a truck sitting ,that does tend to rot the muffler.
Maybe I should the race car trick with springs holding the pipes together.
