8 members (Hotrod Lincoln, Gdads51, Bill Hanlon, JoeDude, frogfarmer, tclederman, gswbbc, dt235sd),
85
Mod | | | Forums66 Topics128,038 Posts1,055,536 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 15 New Guy | | New Guy Joined: Dec 2008 Posts: 15 | The first item on this page is a power steering upgrade. Anyone tried it? It says that all you need is a pump and PS steering box from a later model. Does this work? If it is this simple, why do so many people get later year columns and modify them to fit? http://www.gmcpauls.com/steering60-66.htmThanks, -mcw
1993 Typhoon "Thunder" - Daily Driver 1963 C10 "Whitney" 1967 Camaro "Beast" - Off the jig and finally on the ground again! 2008 Sky Redline - wife's ride
| | | | | Joined: Feb 2007 Posts: 230 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 230 | The other response is spot on. Most folks go to a newer column because it bolts to the newer PS box, and it has tilt. I would add that you probably will want to change out that huge old steering wheel for a smaller, newer one. I used the IDIDIT chrome column, but you can get something from the junk yard a lot cheaper. IDIDIT has real live knowledgable people you can talk to if you get in a jam. If you have a box frame, the REZ adapter plate noted above will need some frame fabrication. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | On the other side I prefer the stock column with my PS conversion. It's pretty simple to cut off and rework the end to accept the steering shaft. My reasons are; the original column and wheel looks..  .. well.. "original", I never tilt the column even in vehicles that have factory tilt, and I like the Signal-Stat 900 switch just fine. Grigg | | | | | Joined: Nov 2004 Posts: 2,401 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,401 | I prefer the original look compared to a newer steering column in an old truck. My '59 Apache has a Cadillac column and power steering gear box (from a previous owner). To me, it doesn't look right. That is one of the first things that I want to improve this year after I get it back on the road. I may try and go with a '68 column (if I can find one) as another "Bolter" suggested. But back to original would okay also.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Dec 2008 Posts: 15 New Guy | | New Guy Joined: Dec 2008 Posts: 15 | What year has an automatic column shift, but NO key? I like keeping the key on the dash, but I don't want a weird hole on the column...
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | absintheisfun, I know the 67/68 has no key on the column and on up into the 70's....but I'm not sure. I have read that a lot of guys are using columns out of Chevy Vans but not sure what years. I think may around 84 and the van columns give you tilt and "no key". I'm sure someone will come in with years/models but at least this will get you to thinking about where some old ones are sitting!! | | | | | Joined: Dec 2008 Posts: 15 New Guy | | New Guy Joined: Dec 2008 Posts: 15 | I wonder if I could use my 67 Camaro column...?
