7 members (Bill Hanlon, Tom McGrath, Rich'sToys, Jman, Robert Crandall, Steelonsteel, Wally / Montana), 85 guests, and 4 robots.
Topics128,035
Posts1,055,556
#498237 01/27/2009 3:36 PM
The first item on this page is a power steering upgrade. Anyone tried it? It says that all you need is a pump and PS steering box from a later model. Does this work? If it is this simple, why do so many people get later year columns and modify them to fit?
http://www.gmcpauls.com/steering60-66.htm
-mcw
1993 Typhoon "Thunder" - Daily Driver
1963 C10 "Whitney"
1967 Camaro "Beast" - Off the jig and finally on the ground again!
2008 Sky Redline - wife's ride
#498378 01/27/2009 10:25 PM
The other response is spot on. Most folks go to a newer column because it bolts to the newer PS box, and it has tilt. I would add that you probably will want to change out that huge old steering wheel for a smaller, newer one. I used the IDIDIT chrome column, but you can get something from the junk yard a lot cheaper. IDIDIT has real live knowledgable people you can talk to if you get in a jam. If you have a box frame, the REZ adapter plate noted above will need some frame fabrication.
Tim K #498414 01/28/2009 12:06 AM
On the other side I prefer the stock column with my PS conversion.
It's pretty simple to cut off and rework the end to accept the steering shaft.
My reasons are; the original column and wheel looks.. headscratch .. well.. "original", I never tilt the column even in vehicles that have factory tilt, and I like the Signal-Stat 900 switch just fine.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Grigg #498480 01/28/2009 2:35 AM
Former Workshop Owner
I prefer the original look compared to a newer steering column in an old truck. My '59 Apache has a Cadillac column and power steering gear box (from a previous owner). To me, it doesn't look right. That is one of the first things that I want to improve this year after I get it back on the road.
I may try and go with a '68 column (if I can find one) as another "Bolter" suggested. But back to original would okay also.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
J Lucas #499495 01/30/2009 2:09 PM
What year has an automatic column shift, but NO key? I like keeping the key on the dash, but I don't want a weird hole on the column...
1963 C10 "Whitney"
absintheisfun, I know the 67/68 has no key on the column and on up into the 70's....but I'm not sure. I have read that a lot of guys are using columns out of Chevy Vans but not sure what years. I think may around 84 and the van columns give you tilt and "no key".
I'm sure someone will come in with years/models but at least this will get you to thinking about where some old ones are sitting!!
Achipmunk #500003 01/31/2009 3:06 PM
I wonder if I could use my 67 Camaro column...?
1963 C10 "Whitney"
