BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
8 members (Guitplayer, Possum, cmayna, Joe W, UtahYork, Greg_H, FAST55, rfs56trk),
522
robot. | Key: Admin,
Mod | | Forums66 Topics126,776 Posts1,039,271 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Jan 2009 Posts: 36 Wrench Fetcher | Wrench Fetcher Joined: Jan 2009 Posts: 36 | does a 48 4400 series rims split in the center or outside
remember rust is our friend
| | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | Shop Shark Joined: Aug 2005 Posts: 1,186 | Could be either but I would suspect it has three piece rims.
Bruce | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The split in center came out latter then that. You have the lock ring type. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | Joined: May 2005 Posts: 8,877 . | . Joined: May 2005 Posts: 8,877 | My 48 had both.. you won't know for sure until you look at them. | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | 'Bolter Joined: Mar 2004 Posts: 3,068 | After 60 years, it could have about anything. You gotta look at each wheel, Scott | | | | Joined: Jan 2009 Posts: 36 Wrench Fetcher | Wrench Fetcher Joined: Jan 2009 Posts: 36 | ok i have looked at each wheel they do not have a ring around the outside i have called several tire shops around here and nobody will mount a tire on a split rim
| | | | Joined: Mar 2004 Posts: 75 Wrench Fetcher | Wrench Fetcher Joined: Mar 2004 Posts: 75 | I have the same problem here in mass. My 65 C50 wrecker came with split rims and nobody will touch them. They are actually illegal to run in this state. You can not get an inspection sticker if they are on your truck. I am still looking for some good used split rims to use. Good luck in your quest. Griggs tech article is great I have hub piloted rims. I would love to buy new but I cant afford them. | | | | Joined: Jan 2009 Posts: 36 Wrench Fetcher | Wrench Fetcher Joined: Jan 2009 Posts: 36 | thanks for the help grigg i found some 19.5 10 lug chevy wheels and tires 50.00 each. is that what you have on yours that you painted red
| | | | Joined: Jul 2008 Posts: 115 Shop Shark | Shop Shark Joined: Jul 2008 Posts: 115 | FWIW, the Firestone RH-5° true "widow maker" split rims first appear in the wheel catalogs in about 1944 or 45 as I recall. And I'll ditto what the others have said. Wheels get damaged and replaced throughout their working lives. A truck can have any mix of styles mounted. Grigg's tech piece has cross section diagrams that will show you the differences. | | | | Joined: May 2005 Posts: 8,877 . | . Joined: May 2005 Posts: 8,877 | thanks for the help grigg i found some 19.5 10 lug chevy wheels and tires 50.00 each. is that what you have on yours that you painted red Sure, glad to help, If you use those wheels you'll need to make the bushings to adapt the 4.75" hub to the 5.25" center hole in the wheel. Also double check that they will fit over your rear drums in particular, and the fronts too. No, the red wheels on my truck are 22.5" wheels, not the smaller 19.5" ones like you have found. Grigg | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | 'Bolter Joined: Mar 2004 Posts: 3,068 | The 19.5's wouldn't fit over the rear drums on my 48 4400 but others have had success. Just thought I would throw out a warning before you got too invested with them. Try them on first, Scott | | | | Joined: Jan 2009 Posts: 36 Wrench Fetcher | Wrench Fetcher Joined: Jan 2009 Posts: 36 | thanks for the info guys you all are a great deal of help.on another note if the 19.5 10 lug wheels wont fit over my brake drum. and i am not able to find anything that fits i did find a guy local said he would mount tires on the split rims for 50.00 each
| | | | Joined: Mar 2004 Posts: 3,068 'Bolter | 'Bolter Joined: Mar 2004 Posts: 3,068 | For that kind of money, you could buy the tools and do it your self, Scott | | | | Joined: Jan 2009 Posts: 36 Wrench Fetcher | Wrench Fetcher Joined: Jan 2009 Posts: 36 | if i did it myself i was thinking when you get it all together bolt it to the hub put a lock chuck on it turn the air on throught a valve i have set up on my compressor and stand back
| | | | Joined: Mar 2004 Posts: 3,068 'Bolter | 'Bolter Joined: Mar 2004 Posts: 3,068 | I wrap log chains around the tire/wheel during inflation to catch the ring if it should blow, Scott | | | | Joined: Jan 2009 Posts: 36 Wrench Fetcher | Wrench Fetcher Joined: Jan 2009 Posts: 36 | i thought about that to. thanks i didnt know the best way to go about it. this is my first big truck
| | | | Joined: Jul 2008 Posts: 50 Wrench Fetcher | Wrench Fetcher Joined: Jul 2008 Posts: 50 | I have split rims on my 49 4400 and they have an one inch ring on the outside of the rim. How dangerous are those?
1949 Chevy 4400 GrainbedIn the Stovebolt GalleryPhotobucket picturesThe taxpayers are sending congressmen on expensive trips abroad. It might be worth it except they keep coming back! Behind every successful rancher is a wife who works in town.
| | | | Joined: Feb 2007 Posts: 20 Apprentice | Apprentice Joined: Feb 2007 Posts: 20 | My 49 4400 has lock rings. After about 2 hours of staring at them, I finally figured out how to break them down and replace the tires without being injured too seriously. | | | | Joined: May 2005 Posts: 8,877 . | . Joined: May 2005 Posts: 8,877 | I have split rims on my 49 4400 and they have an one inch ring on the outside of the rim. How dangerous are those? | | |
