7 members (Lightholder's Dad, Wickedbass, Christian, NJC, Hotrod Lincoln, baldeagle, 1955 1 Series),
59
Mod | | | Forums66 Topics128,017 Posts1,055,338 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | on my 1952 the lower door panel on drivers side the nuts on the door are missing so the panel cant be bolted in whats the best repair the holes are all missed up | | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | well i was able to buy square nuts and weld them in place closer!! closer!!!!! | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Depending on how fussy you are for accuracy you might want to consider "J" or "U" nuts like PICTURED HERE. You can get these at ACE hardware, I believe. I can't remember but I think those might have originally been "cage nuts" like pictured HERE. but I don't recall seeing then at the hardware store. Anyway, there are a couple options to consider. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | woody, can't get those links to open? And I'm not sure what panel he is talking about? On my 52panel the inspection plates are screwed on ....and its screws that hold the cardboard panel on....isn't it? I"m confused  | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Alvin, Well, isn't that messed up?! They were there this morning! Maybe the economy is worse than I thought! Try googling J nuts or U nuts... although now I'm beginning to think I'm nuts. As far as what's supposed to be holding them on I can't help you... THIS is what was holding mine on :mad: | | | | | Joined: Jul 2006 Posts: 79 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 79 | I think Woody is correct. Mine had nuts welded in the door panel similar to cage nuts. I think the modern u-nuts would suffice. I had clutch head screws holding the lower panel, and phillips head screws in the upper (cardboard) panel. (I think they were added later in the truck's life.) Here's a photo of the door before I put the covers on, but you can't see much even zooming the photo to 300%. I really just wanted to show off the gray paint. http://i298.photobucket.com/albums/mm241/rickysahn/1952%20Chevy/x5-1.jpgBluedawg
Bluedawg
God fearing, Gun toting, Constitution loving extremist.
| | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | I just looked at my new doors and they are a kind of cage nut that find in several places on these trucks like on the inner fenders. More like a flanged nut that's permanently mounted, but not welded. About the closest thing you'll find handy today are like the ones seen HERE... if they're still in business by the time I post this. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Woody, I know you probably only posted the link to ABCOR to illustrate the nuts but have you tried buying anything from Them? It appears that they are an OEM supplier not a retail outlet, probably couldn't buy less than 10000 at a time. McMaster is a retailer and would handles some of those style nuts but not a full line of them. DG
Denny G Sandwich, IL
| | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Woody, I know you probably only posted the link to ABCOR to illustrate the nuts Correctamundo  | | |
