1 members (klhansen),
116
Mod | | | Forums66 Topics128,275 Posts1,058,571 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#49869 09/02/2005 2:27 AM | Joined: May 2005 Posts: 2 Junior Member | | Junior Member Joined: May 2005 Posts: 2 | I am getting ready to swap the 235 out of my 46 1 1/2 ton for a 348 and am not sure what to do about the throttle/accelerator pedal and linkage. Can someone who has done a v8 swap in this style truck tell me how and what available parts (if any) are available or donor parts that are suitable in regards to gas pedal and throttle linkage? I need to get this thing rolling Any help is greatly appreciated Thanks  | | |
#49870 09/02/2005 2:44 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | What I did was take the throttle cable and pedal assembly out of any mid 70's chevy truck. After the engine was in, I mounted the cable and carb bracket to the engine and looped the cable in a nice loose loop back to the firewall. I then drilled the hole and used a file to make it square so the cable would stay clipped into the firewall. I attached the pedal assembly to the floor after a little bending and modifing, it was perfect. Good luck, Scott | | |
#49871 09/02/2005 2:58 AM | Joined: May 2005 Posts: 2 Junior Member | | Junior Member Joined: May 2005 Posts: 2 | Scott, Thanks for the info. That sound pretty painless. Thanks again.
Marc | | |
#49872 09/02/2005 3:18 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | jetexas, When you say 348, do you mean Chevrolet V8 348, as in 409 V8? Scalloped heads and valve covers!
Stuart. | | |
#49873 09/17/2005 10:07 PM | Joined: May 2001 Posts: 47 Member | | Member Joined: May 2001 Posts: 47 | jetexas, I went to a near by rod shop and got the pedal and throttle cable. I don't remember what the cost was but it wasn't much and looks nice in the 37. All I had to do was drill one hole in the firewall. Its sort of a "universal" kit. | | |
