0 members (),
91
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 161 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 161 | as I've described before, I burned a hole in a piston. put a new piston in, trying to start it today. well, that went bad. turn it over a few times without the coil hooked up, seems all good. so I hook up the coil, try to start it. engine turns over, that's it. I have spark. carb starts flowing over. so I check if something in the carb is stuck. no, carb is fine. I try starting it a few times more, and then the engine gets stuck. doesn't turn over anymore. !@#$%^&*() is what I thought. so what now? thinking about it, I did hear something that sounded like an air leak, coming from all cylinders. but that might just be the compressed air coming out of the cylinder into the exhaust? I'm getting a little depressed..  | | | | | Joined: Sep 2008 Posts: 87 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 87 | I know what you are feeling I had a 327 that after doing a rebuild it took me forever to get it going again. All I can say I is re-trace your steps. check timing and cam placement if it is stuck I would try and rotate the engine counter clockwise by hand to see if you can dislodge it worse come to worse pull the head off again. | | | | | Joined: Jul 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 461 | Seetz, take out the spark plugs and see if you have a cylinder full of either water or gasoline. If the carburetor is over-flowing, you might have a hydraulic lock. A cylinder full of water also means a hydraulic lock from either the head gasket leaking, or a cracked cylinder or a crack in the head. The carburetor won't over flow unless the needle valve stays open- either stuck or held down, or the float has sunk.
It is not unusual to hear air leakage if you listen carefully from under the hood, and you turn the engine slowly, by hand. Otherwise, you probably won't hear anything.
If either the valve timing or distributor timing is off, it is quite possible to have a satisfactory spark, but the engine will not start. And, don't try push-starting until you are sure the cylinders are not full of liquid.
Harvester | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | If the carb flooded a lot the excess gas could have washed all the oil off the cylinder walls and it siezed up. Take the plugs out and if nothing seem wrong I would put some Marvel Mystery oil in the cylinders and let it set of a couple days. Right now its better to take a little time than cause even more problems. Keep us posted. | | | | | Joined: Jan 2007 Posts: 161 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 161 | alvin I like your answer  sounds like the least trouble.. by the way, love the color on your panel, it's going to be a beautiful ride! | | | | | Joined: Dec 2004 Posts: 425 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 425 | Sounds like the float stuck? Sure you didn't burn up the starter? Or the starter wire? Do you have it set to fire on the compression stroke or exhaust stroke?
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Hi, did You ever find out why the piston had a hole in it to begin with? Maybe this is more of the same problem, did You do a complete rebuild on the motor if the cam timming is off or the dis. is in just one tooth off the motor is never going to run and could cause more failures . Pete | | | | | Joined: Jul 2007 Posts: 224 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 224 | i dont believe it is seized because of gas wash down and if it is you will have cylinder damage if you pull the plugs and it wont turn over it needs to come out and be fixed. even if you get it running it will be on borrowed time. | | | | | Joined: Jan 2007 Posts: 161 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 161 | I always thought that timing doesn't change once it's set? I mean, I've ran this engine for thousands of miles and it ran fantastic. I believe the cause of the hole was this: running too hot, which caused a leak in the intake manifold gasket, which made it run lean, which caused the hole (I actually could SEE the leak in the gasket). and my 'rebuild' was: valve job and replace one piston. so no timing parts touched, and the distributor didn't leave the engine. so I don't believe the timing thing. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | phillip t: it may not be wash down in the end but a possiblity. I remember as far back as 1965 when this happened on a V8 Oldsmobile engine at the dealership. We got it running and it ran many miles but not sure how many! I also saw this some years later on a 6 cylinder. We're waiting Seetz so keep us posted. We all learn from each other!
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Hi, if it turns out to be that You ran the motor that hot to burn a piston the rebuilder should be able to tell , all Your other piston rings may sezed onto Your pistons , try to put some marvel mystery oil into all the pistons but most of the time you are going have to replace all the rings . With that much blowby every thing gas , air is going to blow out of the carb , also do a compression check before You start on the terdown . Pete | | | | | Joined: Jan 2008 Posts: 227 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 227 |  Seetz, It is always hard diagnosing engines over a few posts on a website. When you say the engine "becomes stuck"....is it mechanically seized, or has the battery and starter just run down and won't crank the engine further? Maybe not enough power to turn the engine over fast enough or supply enough spark? You should be able to attach a socket to the front of the crank and see if it will turn over by hand with all the spark plugs removed. Did the engine overheat when it originally holed the piston, or just die in a cloud of exhaust smoke? Could be that other damage was caused when the piston holed and you need to strip, clean and inspect all your bottom end. Until some of these questions are answered, it would be very hard to properly diagnose. HotRod Lincoln or some of the other 'Bolt engine guru's may find this post and offer some of their wisdom. Best of luck............. | | |
