0 members (),
151
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,115 Posts1,056,289 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2004 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 66 | Was the frame height on a '54 4400 the same height or taller than a '54 4100? | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | The only difference would be wheel base. A 4400 and a 4100 are both 1 1/2 tons. Should have the same amount of springs under each providing both are stock originals, Scott | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Stoveboltkid, I'm going to assume you want to compare frame sizes. You didn't specify which model, so I'm going to use the 4108 and 4408 for comparison. 4108 frame dimensions 7" X 2 3/4" X 7/32" section modulus 5.52 4408 frame dimensions 8 7/8" X 2 7/8" X 1/4" section modulus 8.80 so to answer the question the frame on the 4400 series is larger in every dimension, hope that helps. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If you are only interested in frame height, with the same tires and the same springs, you'd have about the same frame height (about 34" - from the information for the 4102 and 4402 models in the 1954 Truck Data Book).
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | The frame for a 4100 is essentially a 1 ton frame with different front bumper mounting details. The frame for a 4400 is the same as a two ton 6400.
The short wheelbase 4100 frame is physically smaller than the longer wheelbase 4400. Just as 3B describes.
Grigg | | | | | Joined: Jun 2004 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 66 | I thought that the 4400 frame might be taller, but i couldn't find another to compare it to. I made a mistake years ago when i stretched my 4100 frame 4 feet to accomodate a 12-foot stake bed. Now i wish i had just started off with a 4400 or a 6400. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Where are you from? I have a bare 54 4400 frame sitting around, Scott | | | | | Joined: Jun 2004 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 66 | I'm in southeastern New mexico | | |
