4 members (Wayne67vert, MickeyP, Otto Skorzeny, Bill Hanlon), 176 guests, and 0 robots.
Topics128,106
Posts1,056,213
Members48,436
#494460 01/17/2009 8:51 PM
Was the frame height on a '54 4400 the same height or taller than a '54 4100?
The only difference would be wheel base. A 4400 and a 4100 are both 1 1/2 tons. Should have the same amount of springs under each providing both are stock originals,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
3B Offline
Hy Stoveboltkid, I'm going to assume you want to compare frame sizes. You didn't specify which model, so I'm going to use the 4108 and 4408 for comparison.
4108 frame dimensions 7" X 2 3/4" X 7/32" section modulus 5.52
4408 frame dimensions 8 7/8" X 2 7/8" X 1/4" section modulus
8.80
so to answer the question the frame on the 4400 series is larger in every dimension, hope that helps.
If you are only interested in frame height, with the same tires and the same springs, you'd have about the same frame height (about 34" - from the information for the 4102 and 4402 models in the 1954 Truck Data Book).
The frame for a 4100 is essentially a 1 ton frame with different front bumper mounting details.
The frame for a 4400 is the same as a two ton 6400.
The short wheelbase 4100 frame is physically smaller than the longer wheelbase 4400. Just as 3B describes.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
I thought that the 4400 frame might be taller, but i couldn't find another to compare it to. I made a mistake years ago when i stretched my 4100 frame 4 feet to accomodate a 12-foot stake bed. Now i wish i had just started off with a 4400 or a 6400.
Where are you from? I have a bare 54 4400 frame sitting around,
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
I'm in southeastern New mexico
