7 members (RdsLessTaken, TUTS 59, Jay R, Otto Skorzeny, 68ironhead, Phak1, 1 invisible), 99 guests, and 3 robots.
Topics128,136
Posts1,056,428
Members48,441
#494121 01/16/2009 11:31 PM
Help, I have looked high and low for a new master cylinder or a rebuild kit. Nobody list parts for anything larger than a C-30. Anyone out there have a source because I an out of places to look. This is a dual brake and clutch unit with 1 1/8 bore on the clutch and 1 3/4 on the brake side.
Thanks ahead of time for any help you can give
Craig
I had good luck finding a master cylinder for a 1957 dodge 3 ton at Kanter auto products, www.kanter.com
Ryan
If you can't find one off the shelf, you could always check with a brake rebuilding shop, like Whitepost Restorations in VA. I'll try to find their info.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
They don't actually mention "Master Cylinders", but they still may be able to help.
http://www.whitepost.com/brake.html
GMC 9500 Fan
Detroit Diesel Fan
Read through this thread:
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Board=5&Number=477600&Searchpage=1&Main=66317&Words=stainless+%2Bsteel+%2Bsleeve+Grigg&topic=0&Search=true#Post477600
It covers your options on having cylinders sleeved and rebuilt.
I'm not a fan of brass sleeved cylinders. Stainless is longer lasting with fewer troubles, and therefore a better option.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
NAPA or CarQwest with a competent counter person can get you one. Ours hasn't let me down yet,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Grigg,
I just read thru the old thread.
Mark "the machinist" Frappier sounds like a good choice. Up till now I never heard of him, but will keep him in mind for future needs or references.
Thanks for posting it.
GMC 9500 Fan
Detroit Diesel Fan
3B Offline
Hy CraiginMO, the largest brake cylinder bore I could find was 1 1/4" all the way up to the 80 series. the Napa numbers are,
UP34404, 1 1/8" brake cylinder, 1 1/8" clutch cylinder $79.49
UP19089, 1 1/4" brake cylinder, 1 1/8" clutch cylinder $214.00
I don't know why the discrepancy in price between the two, hope that helps.
Finally I had some Luck at Car Quest. They had a book that listed the C-60 and another that showed the Master cyl. They said they can get it for $325. I ordered the rebuild kit for $35. Hope it works. Thanks everyone
All fixed. Yeah! Car Quest
