2 members (Nick in Manitou, 1 invisible),
350
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 42 | I have a 1954 235 engine that I want rebuilt. when I call shops they tell me a price and say (that is if it can be rebuilt).What do they mean when they ask that.How could I check to see if it could be rebilt?If the block and heads are good could it be done? | | | | | Joined: Jul 2006 Posts: 79 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 79 | I personally don't believe in such a thing as a "non-rebuildable" engine. Unless maybe the block is in several pieces... But probably what they're talking about is if there are no cracks in the cylinder walls. Bluedawg
Bluedawg
God fearing, Gun toting, Constitution loving extremist.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Or, they might mean: if the cylinders are not already over-bored to the limit, and/or the crankshaft has not been under-ground to the limit.
| | | | | Joined: Jan 2009 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 42 | Should I take the block apart and send it out to get checked.I already took the head off valves & valve springs. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I would completely tear the engine down. Take the following to the machine shop: bare block with main caps (be sure to mark them) crankshaft pistons and rods head
1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Jan 2009 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 42 | bowtie tim thanks for the help.I will do that.I,ll start on the block in the morning.By the way this is the first time I take a engine apart.It look fun,hopefully not to hard.
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Some shops won't warranty the engine work unless they assemble the rotating mass. If you don't care about longevity, assemble it yourself for the experience, Scott | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Be sure to purchase the 1954 shop manual that applies to your engine.Scott has a good point,you might check into the warranty.
