1 members (klhansen), 101 guests, and 1 robot.
Topics128,151
Posts1,056,999
Members48,460
I have a 1954 235 engine that I want rebuilt. when I call shops they tell me a price and say (that is if it can be rebuilt).What do they mean when they ask that.How could I check to see if it could be rebilt?If the block and heads are good could it be done?
I personally don't believe in such a thing as a "non-rebuildable" engine. Unless maybe the block is in several pieces...
But probably what they're talking about is if there are no cracks in the cylinder walls.
Bluedawg
Bluedawg
God fearing, Gun toting, Constitution loving extremist.
Or, they might mean: if the cylinders are not already over-bored to the limit, and/or the crankshaft has not been under-ground to the limit.
Should I take the block apart and send it out to get checked.I already took the head off valves & valve springs.
I would completely tear the engine down.
Take the following to the machine shop:
bare block with main caps (be sure to mark them)
crankshaft
pistons and rods
head
1951 3100 Chevrolet
bowtie tim thanks for the help.I will do that.I,ll start on the block in the morning.By the way this is the first time I take a engine apart.It look fun,hopefully not to hard.
Some shops won't warranty the engine work unless they assemble the rotating mass. If you don't care about longevity, assemble it yourself for the experience,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Be sure to purchase the 1954 shop manual that applies to your engine.Scott has a good point,you might check into the warranty.
1951 3100 Chevrolet
