1 members (TPR57C),
367
Mod | | | Forums66 Topics128,159 Posts1,057,033 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | I hooked up a temporary exhaust out of a discarded system from another truck. I ran it out of the sides in front of the rear wheels. I like the looks and it sounds pretty good standing on the outside but those Flowmasters are a tad too loud on the inside of the cab. Where are you guys running yours? The sides or the rear?
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I just came in from working on my exhaust... It will exit behind the right rear wheel at an angle both back and to the side.
Grigg | | | | | Joined: Oct 2007 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 63 | Ran my pipes out the back. I think doing long miles with the pipes drumming out the side you may need a loud stereo. Have taken my truck on several runs recently covering 1100kms or 650 miles in 4 days out the back is the way to go personnel choice | | | | | Joined: Dec 2008 Posts: 11 New Guy | | New Guy Joined: Dec 2008 Posts: 11 | When I had the first 292 in my 67 I had dual tuned headers on it with glasspacks, with both pipes dumpin in front of the drivers rear tire. I couldn't take it on any long trips with out bein deaf in my left ear
60 Apache 4X4 235 67 C20 292 90 Dodge W250 Cummins
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | I've had mine run right to the rear. It's a bit tight on account of the Air suspension but as the others say side exits would be tiring on a long drive. (As much as I like the V8 'rumble!) Plus I prefer the look at the rear.
I might have to adjust the silencers once I get the drive shaft in place to allow for suspension movement and the pipes just clear on full compression at the axle. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Currently mine exits in front of the rear wheels, this spring I plan on taking it to have pipes bent to run it out the rear as it is annoying on a long drive. | | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | i have flowmasters,was planning on them running to the rear but the fuel cell mounts put a halt to that.i'm thinking about using turn downs and dumping them in front of the rear axle...............dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Robert, move the mufflers back if you can and get the tail pipes to exit as far back as possible. This will quiet down the sound in the cab. Exiting any where before the rear wheels turns the cab and box into a sounding board. Think of it as having your head inside the drum.
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Hi Stuart, does this look familiar? I didn't copy yours! Honest!  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | Mine are out back. 2.5 inch into 3 inch stainless tailpipes with flowmasters. It has great lowend bark. | | | | | Joined: Nov 2005 Posts: 238 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 238 | Hi Stuart, does this look familiar? I didn't copy yours! Honest!  That looks good, is your truck on the road now? Not enough running Stovebolts in the UK yet. Have a great hogmanay. Stuart. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | 292 dual 3+3 Langdon headers. the quietest walker under the bed. full cab insulation both inside and on the cab bottom. 2 into 1. out the left rear corner, cause i have a spare tire in back w/ a crank down cable.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Feb 2006 Posts: 346 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 346 | Let me ask you guys that said it's really loud in the cab. Have any of you put an insulaton package inside the cab,floor,doors ect? Would that make a differance or not? Just wondering. Thanks
Terry K.
1951 5 window 1/2 ton
The only way to have a friend is to be one. -Ralph Waldo Emerson-
| | | | | Joined: Dec 2008 Posts: 11 New Guy | | New Guy Joined: Dec 2008 Posts: 11 | I don't have any insulation in the cab, Shoot I don't even have carpet or a rubber mat. But the sound is bearable with the window up.
The only time it really gets annoying is when I'm screamin down the interstate at 65-75mph
| | | | | Joined: Aug 2008 Posts: 403 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 403 | They have several products that deaden the sound and one that I know of that is water proof. You can find this stuff at the hot rod stores. 62Blue Don
62Blue 62Chevy in progress You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
| | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | Thanks for your replies.Looks like the majority of you guys are running them out back, which is what I'll do when I can get it to a muffler shop. How about some pics  of your exhaust tips. I'm thinking about the Camaro style.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Nov 2006 Posts: 677 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 677 | I ran mine like This It turned out nice and clean. BUT now that Im looking into installing a gas tank under the bed Im going to have to do something different so that I can fit the tank in between the frame rails Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs. 1951 3100 350 TBI Gallery Toddzilla... "$old" | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Thanks for your replies.Looks like the majority of you guys are running them out back, which is what I'll do when I can get it to a muffler shop. How about some pics  of your exhaust tips. I'm thinking about the Camaro style. I got my exhaust guy to leave the tail sections slightly long as I haven't decided wheather to have a rolled pan or to just leave as is. I'll wait 'till I get the bed back on! The Camaro tips are nice though! 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Hi Stuart, does this look familiar? I didn't copy yours! Honest!  That looks good, is your truck on the road now? Not enough running Stovebolts in the UK yet. Have a great hogmanay. Stuart ....I didn't want to hijack Robert C's thread but no she isn't quite there yet,I've still got a bit to do! Hopefully this year! Stuart.
| | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | On my 55 with Flowmasters they exit out the back.They arent really loud,but have a nice rumble to them. On my 65 They exit in front of the back wheels with turbo mufflers. I like both setups,so to me its just a matter of personal preference.However I would say,that if your gonna exit them in front of your rear,axle,to use quieter mufflers. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | How about some pics of your exhaust tips. I'm thinking about the Camaro style.
just a 2.25'' round pipe
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Here's a picture of my newly installed exhaust "tip" really no tip at all, just a 5" pipe. http://rides.webshots.com/photo/2892389310080251109PyZeSUThe rest of the system is 4" mandrel bent from the turbo to behind the cab. Then 5" and a Magnaflow Stainless steel muffler and some more 5" with mandrel bends to get over the axle. Grigg
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Grigg, if it still sounds anything like it did in your video...it'll be great! 5" looks huge!  Kitty didn't look too impressed though!  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Feb 2006 Posts: 150 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 150 | My 54 3100 has a 283, power pak heads, Pertronix Kit, Rams Horns, and no-name turbos exiting just before the rear wheels. I love the sound of it around town (which is 90% of my driving) but This past weekend I took it Old Town Saturday Night Cruise, about 90 miles one way. That's about 2 hours of 3K rpms...yeah that can get to ya. My solution is an OD transmission so I can go 70 at or under 2500 rpms.
IF the exhaust must exit the rear on a truck.... I like mostly hidden by the rear bumper, exiting near the rear corners and the exhaust pipe tips angles down at about a 45 degree angle and just bearly peeking below the bumper. I'm trying to think of what cars had a setup like what I'm trying to explain. In short, I (this is personal taste) don't care for seeing 2 pipes dumping straight out the back on a truck.
My hope is you end up with exactly what you like to see and tone you enjoy. Good Luck. | | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | | | | | | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | My '54 GMC 248 has Fenton cast iron headers, 2" pipes back to Corvair Turbo Mufflers then 2" tailpipes out the back. Hardly hear any exhaust noise except when I get on the gas hard in 1st or 2nd gear, nothing at all inside the cab at freeway speed. | | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | I've got a V8 and I'm running them out just in front of each rear tire. The downpipes feed directly into an x-pipe crossover just under the transmission crossmember, and then straight into a pair of Thrush superturbo mufflers and then 45 degrees to angle in front of the rear tires and out with a nice pair of Hearthrob chrome tips. 2.5 inch mandrel bent aluminized pipes all the way back too. My headers are '86 Corvette shorty headers.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | |
