3 members (GMCJammer51, 66flea, Southerntruck), 84 guests, and 2 robots.
Topics128,049
Posts1,055,682
I have flywheel but not sure what it fits. I've had several around the shop and now down to just this one.....
It has GM42 on it and also what I believe to be the part# or casting # is 83875 777 Can anyone tell me what year it is?? I think its an early 50's??
SEE MY POST BELOW THE CORRECT PART # is 839764 - 777. THANKS
83875 does not show up in the 1929-1951 Master Parts Catalog I have.Sorry.
Drew
I'm thinking it came out of a 52 but not sure.....Maybe thats why it doesn't show in the 29-51?
Thanks for looking. Anyone else have any idea?
It does not show up in the 29-57 MPB, either.
What are its characteristics and key dimensions (# of ring gear teeth, pressure plate bolt pattern, diameter, etc.)? Do you have a photo?
OOOOOOOK, I went back and washed/rubbed and sanded the #'s and I made a mistake on the #'s above. No wonder no one can tell me what it is.
The CORRECT # is 839764-777 and it has 139 teeth.
Dang, I don't know where that first # came from..maybe a telephone # smile Sorry gang.
Could the number be 839754?
Master Parts Catalog page
hoyt: I just went back out in the shop and double double checked and it is plainly 839764 then a dash and 777.
Its also 14 inches across and the face where the clutch rubs looks like it uses a 10 3/4" clutch.
3B Offline
Hy Achipmunk, how many bolts hold the clutch to the flywheel?
3B.....I got to get on the school bus right now but I'll let you know later this afternoon. Thanks for any help.....I still believe this is the one out of my 52 panel ???? but its been long time and so much stuff mixed up..and who is to say where it came from over the past years?!!
Alvin,
Your flywheel is PRE 1955. 1955 and later ONLY used 153t or 168t
on full sized engines. Are you sure the flywheel is Chevy?
Les
I can't help you Chipmunk. That number isn't in the 1946-72 truck parts catalog.
Les, I KNOW it came out of a chevy!
TC's: now that does confuse me!
3B: from the marks on the flywheel, left by the pressure plate I count 9 holes.
This really has me confused. Hmmm. Hope this info helps. But I know the numbers I gave, the corrected ones, are correct and I recounted the teeth. I did think the holes 3B ask about were sort of strange but it sure looks like the pressure plate had 9 holes holding it on.
hey, maybe I need to take a close up picture?
3B Offline
Hy Achipmunk and guys, I think your flywheel might be p/n 3705387, 42 - 53 heavy duty clutch, 9 holes, supposed to be stamped "2UC". In hoyt's posting of 01/03/09 there is a link to the parts manual, the descriptions include casting numbers, the casting number you quoted is not listed there, so this is a total surmise on my part, using the facts provided, hope that helps.
I'm gonna bead blast it tomorrow and see what is behind all the crude. I know the #'s I listed are what is on it but they may be some other clue hidden??
I'll update tomorrow evening.
Hey guys, I found this thread online searching the very same casting number Jerry was asking about. An Inliner buddy of mine gave me a flywheel tonight for my 216 and the casting number is 839764 - 777 just like Jerry's! Looks like the conversation died and no one ever figured out what the flywheel came out of or fits. Anybody have new resources that can figure it out now? It's been since January 2009 since this topic was last discussed.
Chuck
Chuck
1941 Chevy coupe
1938 Chevy coupe streetrod
