1 members (WingWright),
103
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I have flywheel but not sure what it fits. I've had several around the shop and now down to just this one.....
It has GM42 on it and also what I believe to be the part# or casting # is 83875 777 Can anyone tell me what year it is?? I think its an early 50's??
SEE MY POST BELOW THE CORRECT PART # is 839764 - 777. THANKS
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | 83875 does not show up in the 1929-1951 Master Parts Catalog I have.Sorry.
Drew
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I'm thinking it came out of a 52 but not sure.....Maybe thats why it doesn't show in the 29-51? Thanks for looking. Anyone else have any idea? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | It does not show up in the 29-57 MPB, either.
| | | | | Joined: Jun 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 388 | What are its characteristics and key dimensions (# of ring gear teeth, pressure plate bolt pattern, diameter, etc.)? Do you have a photo?
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | OOOOOOOK, I went back and washed/rubbed and sanded the #'s and I made a mistake on the #'s above. No wonder no one can tell me what it is. The CORRECT # is 839764-777 and it has 139 teeth. Dang, I don't know where that first # came from..maybe a telephone #  Sorry gang. | | | | | Joined: Jun 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 388 | Could the number be 839754? Master Parts Catalog page | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | hoyt: I just went back out in the shop and double double checked and it is plainly 839764 then a dash and 777.
Its also 14 inches across and the face where the clutch rubs looks like it uses a 10 3/4" clutch.
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Achipmunk, how many bolts hold the clutch to the flywheel? | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | 3B.....I got to get on the school bus right now but I'll let you know later this afternoon. Thanks for any help.....I still believe this is the one out of my 52 panel ???? but its been long time and so much stuff mixed up..and who is to say where it came from over the past years?!! | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | 3B.....I got to get on the school bus right now but I'll let you know later this afternoon. Thanks for any help.....I still believe this is the one out of my 52 panel ???? but its been long time and so much stuff mixed up..and who is to say where it came from over the past years?!! | | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | Alvin,
Your flywheel is PRE 1955. 1955 and later ONLY used 153t or 168t on full sized engines. Are you sure the flywheel is Chevy?
Les | | | | | Joined: Jul 2006 Posts: 40 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 40 | I can't help you Chipmunk. That number isn't in the 1946-72 truck parts catalog. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Les, I KNOW it came out of a chevy!
TC's: now that does confuse me!
3B: from the marks on the flywheel, left by the pressure plate I count 9 holes.
This really has me confused. Hmmm. Hope this info helps. But I know the numbers I gave, the corrected ones, are correct and I recounted the teeth. I did think the holes 3B ask about were sort of strange but it sure looks like the pressure plate had 9 holes holding it on. hey, maybe I need to take a close up picture? | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Achipmunk and guys, I think your flywheel might be p/n 3705387, 42 - 53 heavy duty clutch, 9 holes, supposed to be stamped "2UC". In hoyt's posting of 01/03/09 there is a link to the parts manual, the descriptions include casting numbers, the casting number you quoted is not listed there, so this is a total surmise on my part, using the facts provided, hope that helps. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I'm gonna bead blast it tomorrow and see what is behind all the crude. I know the #'s I listed are what is on it but they may be some other clue hidden?? I'll update tomorrow evening. | | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | Hey guys, I found this thread online searching the very same casting number Jerry was asking about. An Inliner buddy of mine gave me a flywheel tonight for my 216 and the casting number is 839764 - 777 just like Jerry's! Looks like the conversation died and no one ever figured out what the flywheel came out of or fits. Anybody have new resources that can figure it out now? It's been since January 2009 since this topic was last discussed.
Thanks, Chuck
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | |
