0 members (),
192
0
Mod | | | Forums66 Topics128,089 Posts1,056,143 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2002 Posts: 153 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 153 | Info: full pressure 235 with adaptor plate and 1954 216 water pump instead of short water pump, T-5, 3.42 rear end
I went to the local salvage yard and raided a 1941-1946 big bolt for heavy duty (3" instead of stock 2") radiator. I also got the water pump because I wanted the six blade fan.
I cannot get the fan off the pump. There is a large thick bushing on the shaft in front of the fan. Is it supposed to be part of the fan or a separate piece?
With the four bolts out of the pulley I can rotate the fan but the bushing stays tight with the shaft. I removed the back plate from the water pump but I cannot drive the shaft out of the fan/bushing with a punch. Any ideas?
Also, the master parts catalog says that the six blade fan is "for low speed operation". I assumed that the six blade would be better than the four blade. Maybe I shouldn't use the six blade for a half ton. Any ideas?
Thanks, 1946 Chevy Half Ton ('56 235, '86 T5, '79 Camaro Z28 rear end, working on the '85 Jaguar XJ6 IFS) 1976 Margay Panther X, MC91B | | | | | Joined: Nov 2004 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 121 | About the only thing I would do is to heat it up. Being that old, it is probably rusted on the shaft. | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Is it possible there is an allen screw in the bushing holding it on?
Bruce | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | On the fan blade, I've seen a few old fans shoot a blade through the hood! I'd buy a new fan just for safety sake and hang the old one on the wall. | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I took off the seven blade fan that was on my truck and put on a correct 4 blade unit. | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | To get back to the problem..I would first give the fan/shaft assy. a good shot of PB Blaster let is set over night if that doesnt free it put a little heat to the fan via a accetalene torch till red bought 1/2" from the shaft to expand the fan assy. and release its grip on the shaft. just my 2 pennies. Tim | | | | | Joined: Sep 2006 Posts: 206 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 206 | I see you used a punch,Is the end of the shaft mushroomed??May have to clean it up with a file if you can get to it? | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | What looks like a bushing is part of the pulley. The fan has a center hole about one inch in diameter.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2002 Posts: 153 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 153 | Wow. Lot's and lot's of ideas. Thank you all.
I did try heat but only with propane. I did the PB blaster a dozen times. No allen screw. I had ground off a little bit to be sure it wasn't mushroomed.
Sooooo. It's part of the pulley? Well duh. That would makes sense. I will try that tomorrow.
Again Thanks to everyone! 1946 Chevy Half Ton ('56 235, '86 T5, '79 Camaro Z28 rear end, working on the '85 Jaguar XJ6 IFS) 1976 Margay Panther X, MC91B | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | bring in to the Ft. Worth meet and cletis will remove it for you.. Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | What Dave said.
The bushing is part of the pulley. Try just heating the thinner metal of the fan all around the center hub. | | | | | Joined: Mar 2002 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 384 | Did you ever get it off? How?
55 1st Chev.
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I was working on our '40 this past year and had the same issue getting the fan blade off when replacing the water pump. I took the pump off and got it in secured in the vise and then sprayed things with penetrating oil good. The I used a small amount of heat with a torch but was careful not to get so hot that I overheated the water pump shaft. A couple of heat and cool cycles along with a couple soakings of penetrating oil it came right off. I still have the old pump and going to have it rebuilt. Good Luck Don | | | | | Joined: Mar 2002 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 384 | Thanks for the tips. I have the pump off and will try your methods. I will be getting the rebuilt pump from napa today, so i can take a look at it to see what is the shaft and what is the fan so I know what to beat on.
Scott
55 1st Chev.
| | | | | Joined: Mar 2002 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 384 | Once I saw the new one, I could see that the center shaft and the collar both came with the pump...nothing with the fan. I drove a putty knife between the fan and the pulley from every direction and it came off easily.
FYI - Scott
55 1st Chev.
