3 members (Bucker, 3B, Snowman51),
94
0
Mod | | | Forums66 Topics128,157 Posts1,056,893 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 67 | Hi. My name is Chuck. I have a 1949 Chevy 3100 Factory 216, Granny 4-speed, all stock. I've had it about a year, and haven't done much with it yet. I bought it while I was living in Reno, NV, and have moved back down to So. Cal. and bucks are tight. I drive it with a cracked block, and she still gets me around. I am looking for a new engine. I am planning to lower it someday. I have put straight pipes on the 216. She sounds GREAT! I can't wait to get started here. Have a great New Year! Chuck
| | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | Welcome to the Bolt, Chuck. Lots of good people here with lots of info!! | | | | | Joined: Dec 2008 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 67 | Thanks! Have a great day.
| | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Welcome Chuck, it's great to see people keep the old inline sixes in their trucks. I'm still building mine but it has the six with the old 420 4 speed. I hope you like it here; I'm sure you will. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 |  Welcome, pull up a chair and join right in anytime. Look forward to seeing you around the garage. | | | | | Joined: May 2005 Posts: 323 Shop Shark | | Shop Shark Joined: May 2005 Posts: 323 | Welcome to the 'bolt, Chuck  Since Achipmunk didn't mention it, I will... We like  | | | | | Joined: Feb 2006 Posts: 346 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 346 | Welcome to the Stovebolt, Chuck.  Happy New Year to you as well!
Terry K.
1951 5 window 1/2 ton
The only way to have a friend is to be one. -Ralph Waldo Emerson-
| | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | | | | | | Joined: Oct 2005 Posts: 688 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 688 | welcome to the bolt
Cliff59 | | | | | Joined: Dec 2008 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 67 | Welcome Chuck, it's great to see people keep the old inline sixes in their trucks. I'm still building mine but it has the six with the old 420 4 speed. I hope you like it here; I'm sure you will. What is a 420? I'm looking for a 235 to replace my 216. my 216 has a crack under the 6th cylinder. Water leaks out very slowly and I'm just waiting for the crack to get to long. thanks. | | | | | Joined: Mar 2006 Posts: 319 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 319 | Hey, nice to have you aboard, Chuck. The "420 4 speed" is explained rather well at this page. http://www.novak-adapt.com/knowledge/sm420.htm
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
| | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Chuck, my engine is an inline six. I took out the 235 for a 261. The transmission is known as a SM420, SM is synchro mesh and 420 is the model number of it. It is a heavy old 4 speed with a granny gear low. More info on it is available in the driveline forum. | | | | | Joined: Dec 2008 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 67 | Chuck, my engine is an inline six. I took out the 235 for a 261. The transmission is known as a SM420, SM is synchro mesh and 420 is the model number of it. It is a heavy old 4 speed with a granny gear low. More info on it is available in the driveline forum. It sounds like the 420 is my transmission, top loaded with a granny-gear. You said you put in a 261...how did you do it? Thanks for the info! | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Chuck, we better move over to the 'engine and driveline shop' and make room for more newbies in here. That way others can help out as well. There is actually a thread there now titled "getting started and need your opinions" Just jump in.
