4 members (thekid1950, Peggy M, RoadsScholar, Hanks custodian), 164 guests, and 2 robots.
Topics128,080
Posts1,056,063
Members48,433
#485519 12/23/2008 1:23 PM
Should the Radiator be mounted on any special isolators or can it be bolted down directly to the frame?
YES you should use a rubber isolater,I used a chunk of 1/2" thick conveyor belt for spacers under my radiator support.
1952 Chevy Shortbed
Photos in Photobucket
Most vendors sell support pads but you can cut your own with an old tire or firetruck hoses or like SW said with conveyor belt.
http://www.classicparts.com/1950-54-Radiator-Support-Mounting-Pads/productinfo/78-622/
~Jim
i am really cheap so what i did with my racecar is i split radiator hose (that i had kickin around in the shop) the long way and then cut sections you will need them to keep everything bouncing along in the radiator brackets. it seems to work really well on the dirt track we run on.
1951 Chevy 3800 1-Ton
Howard Knapp
i used 3/16'' hard rubber (what i had in the shop laying around after buying all that scrap at capital rubber sacto, cal.) as the bottom radiator core pad (NOT RADIATOR FRAME SUPPORT) and both upper radiator core side attachments.
http://www.capitalrubberco.com/
i used E-6000 glue to hold the bottom rubber in situ.
http://www.createforless.com/Eclect...amp;zmas=1&zmac=22&zmap=28407550
Jim & Caroline
Jim:
What was it you did with the glue?
~Jim
I think along with the pads you have some shims on AD models to raise the radiator bracket to help in getting the fenders/hood to fit up nicely.
I used a 3/16'' rubber pad under the radiator core's new bottom 'U' shaped bracket which is welded to the radiator's main frame that the rad. sits down into. The glue holds the rubber in place so vibration does not move it. the upper supports are changed so that wouldn't apply to any bolters, just in my case. I'll take photos today so they'll be in my next batch of film to get developed. my radiator main frame sits directly on the truck frame right now w/ two 3/8'' carrage bolts holding the bottom, as in my photos. I'm still trying to get the hood to fit properely and hope i don't have to mess w/ the rad frame again. it's bad enough i have to pull the radiator again to fit my fenders under the two ears or tabs that hold the rad. frame to the fender supports. this can get/is timeconsuming. It's not appearant to me exactly where the radiator sits with-in it's frame, it could have been moved more forward and i would not have needed a pusher fan. The relationship of the rad. main frame DOES effect the fender supports and brackets of the hood. i guess if i pull the radiator to fit the fenders it's not that big a deal @ this point. frown
Jim & Caroline
I took a 2 1/2 or 3" hole saw in a drill on some sidewalls of old tires. Goes real quick.
I get it now dang
morepower16 stated RADIATOR ......... radiator what?????????
Not Radiator frame... eek
We're talking two different things here
radiator frame pads ..................... and .................... raditor core pad
the next link is for the radiator frame bottom pads that fit under the main rad. frame to truck chassis frame.
and I took him at his word .......... radiator thinking core ................ not frame.
so morepower16 do you mean radiator core or radiator frame ?????????????? headscratch headscratch
Jim & Caroline
The pads in the Chevy Duty page listed as 47-49 pads are also for my 51 3/4 ton. There is a difference between 3100 and the 3600 at the radiator support. The correct terminology is radiator support.
As I read the assembly manual the only cushions appear to the be pad between the rad support and the crossmember.
~Jim
ok
but I added my own radiator pad
so now i know.
what was morepower16 thinking when HE asked this question ???
& we don't know what year truck he speaks of ??
Jim & Caroline
Sorry so long to reply but I have a 54 that I'm putting a custom radiator in with a custom mount and just looking for info about the need to put a vibration dampner somewhere in the mounting of the radiator, whether it is to the custom mount or the chassis. If I use rigid mounts for the entire thing, what will happen?
Originally Posted by morepower16
Sorry so long to reply but I have a 54 that I'm putting a custom radiator in with a custom mount and just looking for info about the need to put a vibration dampener somewhere in the mounting of the radiator, whether it is to the custom mount or the chassis. If I use rigid mounts for the entire thing, what will happen?
It's hard to say unless you've seen it before. The design engineers thought it best to cushion the support and I will follow that in fear of what might crack if I don't. We can give better/correct advice if we can see what you're doing. Got a camera? pix
~Jim
