7 members (fonz8261, 1955 1 Series, FrankenChevy, 78buckshot, Gdads51, Gray_Ghost, 1 invisible),
100
Mod | | | Forums66 Topics128,180 Posts1,057,067 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 35 | I wanted to let you guys know if you have wore out spindles that new bushings are to loose, there is a fix. I drop axles and get allot of wore out spindles in. I was at the parts store the other day and there was a new kid there that could not read the book! (You Know the Type). I was wanting king pins for a 51 Chevy. I said I would look it up myself. It was a MOOG book and I came across two different sets. They were both the same in every way except bushing OD. Stock Bushing OD is 1.0537 the other set had 1.0782 OD bushings. I ordered both sets. When I got them in it was just what I wanted. I took a reamer and reamed out the wore out spindle bushing holes and installed the bigger bushings. Now for all those 30 wore out spindles that I was going to toss I have a fix. The Moog part# for the king pin set with oversize bushings is 8451B I looked at the NAPA parts book and they don't have a king pin set with the bigger bushings. | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | | | |
