| | | Forums66 Topics128,139 Posts1,056,455 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 17 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 17 | Hello all, first off ,this is a great site. visited a few times to browse. I have a 1972 c10,bone stock,key and a heater,driven daily. my current project is a 51 3600. I have completly refurbished an s10 chassis to put under it. plan to purchase frame swap kit from advanced design engineering.I gutted the cab last weekend and am trying to build up the courage to replace cab corners. have a great day
| | | | | Joined: May 2005 Posts: 323 Shop Shark | | Shop Shark Joined: May 2005 Posts: 323 | Welcome to the 'bolt, oldblue51, the more the merrier  Looking forward to seeing  of both your trucks. Good going on replacing those cab corners, get 'er done  You sound like you're not one to drag your feet  | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Welcome, oldblue51. So you have two old trucks, great! Sounds like you have a good plan of attack, as Sab says, get 'er done! If you run stuck, you know where to go now. | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Hi oldblue51, Welcome  Have a plan and stick to it. Remember...when you get round to tackling the cab corners,measure twice...cut once! I managed to do mine on my '50. If I can do it you can! Jock  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Howdy and welcome to the best site for old chevy trucks! Glad ot have you with us and look forward to lots of pictures! | | | | | Joined: Sep 2006 Posts: 206 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 206 | Over 30 years ago,I guy from colarado I knew had an old truck he called old blue.Don't rember the year of it but He drove it to northern Wi one summer.I fixed the spring's in the starter on it. This by chance wouldn't be the same guy would it?Tom | | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | Good to have you aboard, great site with lots of info!! | | | | | Joined: Oct 2005 Posts: 688 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 688 | welcome to the bolt!  Cliff59 | | |
