3 members (Materman, blanch53, 1 invisible), 125 guests, and 2 robots.
Topics128,072
Posts1,055,906
Members48,429
#462920 10/19/2008 3:54 AM
I have a 305 chevy for my 48 chevy truck. I already have the motor and would like to use it. I am hoping to get around 275 horepower and 300 ft pounds of torque. A 350 would be easier but I want to use what I have any suggestions.
#462993 10/19/2008 3:56 PM
Install a set of Sealed Power flattop hypereutectic pistons, a Comp Cams 268H cam, and a set of 58CC heads with 1.94" intake valves and 1.6" exhausts, with .550" lift single valve springs. Get a factory aluminum intake and a Quadrajet carb, and run dual exhausts with stock cast iron exhaust manifolds and 2 1/2" pipes through mid-70's Cadillac mufflers. You'll make your target HP and torque, with a building cost for the engine of just under $3,000.00.
Edit: Drop by my shop at McGavock High School in Nashville, and I'll put you in touch with several people at the fairgrounds race track who run my engines, some of them 305's. They like them!
Hi,
I did the same for my 305 with all of the excellent advice from Jerry, exept for the pistons, that will be for the next overhaul.
If You have any questions ask Jerry or me.
I also used ram-horns.
1942 Chevy pick-up.
Allthe best,
Jan
Don't waste water, drink wine !
1946 Chevrolet 1/2-Ton Truck
Even in stock config, I think it's a good motor. Have used several and liked them all. Just think like its a 283 with bigger pistons and keep the oil changed and run it like you stole it!!
dg
DGERTH #465959 10/29/2008 1:34 PM
305's are bringing a premium in this area. Demand is higher than 350's by far. Keep it.
gazim #466069 10/29/2008 7:43 PM
Some of the 305s of the mid 80s were real screamers.I had one in a 56 Chevy sedan,and it was a real runner and very economical to operate.Better known as high performance 305s.They were used in Camaros,Monte Carlos,and some Pontiacs right around 1984.Mine had a highrise Edelbrock manifold and 600CFM Edelbrock carb.and stock exhaust manifolds with dual exhaust.That car is stiil around and running just great,and is for sale for $35,000.
dale937 #483950 12/19/2008 5:20 AM
1 Offline
A little late on the post, sorry. I have a 305 in my delivery. Put a set of late model vortec heads (for a 305), a low end Crane came, Performer vortec intake, and a Holley 650. Waiting on headers to crank it up. Did a lot of research on the 305. Round trackers around here like them. Heads make the difference. Should be over 300hp
1949panel #483985 12/19/2008 1:16 PM
I swapped in a cam and heads on my sisters car. Dont know the outcome, however it woke the engine up fairly well.
DGERTH #484010 12/19/2008 3:04 PM
A 283 is a totally different animal. The 305 has close to a 265 bore, and a 350 stroke. That translates to lots of low end torque, but nowhere near the 8,000+ RPM capability of the 283. Gear it high, and keep the RPM down to a reasonable level, and the 305 is a good choice. Just don't get crazy with the top speed before you shift.
