1 members (delky),
65
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 46 | I have a 305 chevy for my 48 chevy truck. I already have the motor and would like to use it. I am hoping to get around 275 horepower and 300 ft pounds of torque. A 350 would be easier but I want to use what I have any suggestions. | | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | Install a set of Sealed Power flattop hypereutectic pistons, a Comp Cams 268H cam, and a set of 58CC heads with 1.94" intake valves and 1.6" exhausts, with .550" lift single valve springs. Get a factory aluminum intake and a Quadrajet carb, and run dual exhausts with stock cast iron exhaust manifolds and 2 1/2" pipes through mid-70's Cadillac mufflers. You'll make your target HP and torque, with a building cost for the engine of just under $3,000.00. Jerry
Edit: Drop by my shop at McGavock High School in Nashville, and I'll put you in touch with several people at the fairgrounds race track who run my engines, some of them 305's. They like them! Jerry
| | | | | Joined: May 2005 Posts: 96 Shop Shark | | Shop Shark Joined: May 2005 Posts: 96 | Hi,
I did the same for my 305 with all of the excellent advice from Jerry, exept for the pistons, that will be for the next overhaul.
If You have any questions ask Jerry or me.
I also used ram-horns.
1942 Chevy pick-up.
Allthe best,
Jan | | | | | Joined: Oct 2007 Posts: 84 New Guy | | New Guy Joined: Oct 2007 Posts: 84 | Even in stock config, I think it's a good motor. Have used several and liked them all. Just think like its a 283 with bigger pistons and keep the oil changed and run it like you stole it!! dg | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | 305's are bringing a premium in this area. Demand is higher than 350's by far. Keep it. | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | Some of the 305s of the mid 80s were real screamers.I had one in a 56 Chevy sedan,and it was a real runner and very economical to operate.Better known as high performance 305s.They were used in Camaros,Monte Carlos,and some Pontiacs right around 1984.Mine had a highrise Edelbrock manifold and 600CFM Edelbrock carb.and stock exhaust manifolds with dual exhaust.That car is stiil around and running just great,and is for sale for $35,000. | | | | | Joined: Apr 2008 Posts: 17 New Guy | | New Guy Joined: Apr 2008 Posts: 17 | A little late on the post, sorry. I have a 305 in my delivery. Put a set of late model vortec heads (for a 305), a low end Crane came, Performer vortec intake, and a Holley 650. Waiting on headers to crank it up. Did a lot of research on the 305. Round trackers around here like them. Heads make the difference. Should be over 300hp | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | I swapped in a cam and heads on my sisters car. Dont know the outcome, however it woke the engine up fairly well.
| | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | A 283 is a totally different animal. The 305 has close to a 265 bore, and a 350 stroke. That translates to lots of low end torque, but nowhere near the 8,000+ RPM capability of the 283. Gear it high, and keep the RPM down to a reasonable level, and the 305 is a good choice. Just don't get crazy with the top speed before you shift. Jerry
