1 members (Hotrod Lincoln),
73
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#48261 07/27/2005 4:07 AM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Might need front drums for my 49. Seems they are only available as reproductions and most are made off-shore. Anybody know of an American company that still makes these? | | |
#48262 07/27/2005 5:57 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | blu - you won't find such a thing, and are lucky to even find repops - didn't know anyone was doing the earlier ones - the ones from 50-something [3?] to 60-something are still available from stock, but I've heard they're also no longer being made
what I've seen regarding the Huck droms: "these are getting very hard to find new, and used drums are usually worn oversized. The best advice is to not turn drums unless absolutely necessary. When our trucks were in everyday use, drums were almost never turned and rarely presented problems.
If grooves are cut into drums from over-worn riveted linings, new linings will eventually seat into the grooves. If the grooves are really deep, it is time to go hunting for new drums. One of my parts trucks had a drum split along a rivet groove. This is a good argument for installing bonded linings - no rivets to gouge drums."
you might search for some used and get lucky
Bill | | |
#48263 07/27/2005 2:36 PM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Bill I agree but my front are oval shape methinks because I get pulsations thru the pedal when I apply the brakes. Might have to search out some Bendix types. This will require some of the holes in the spindles to be enlarged. As far as performance with the Huck style goes, I have always had adequate braking. Then again I don't drive fast. Bill | | |
#48264 07/27/2005 9:11 PM | Joined: Jan 2005 Posts: 19 Junior Member | | Junior Member Joined: Jan 2005 Posts: 19 | We understand that "offshore" probably means China and that their quality sometimes leaves a little to be desired.
Still, where did you see these drums? Any for the 3/4 ton?
Gary
P.S. I had to replace the manifold on my old Ford tractor and could only get a Chinese copy. The first one I got had a casting hole right through it. The company made good and the replacement has been on the tractor for several years with no problems. I know: brakes are more critical. | | |
#48265 07/27/2005 9:44 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Jim carter has drums listed for the 1/2 Ton and 3/4 from 1937 to 1950. I haven't heard any complaints about the new drums. I am sure I have seen other vendors selling them too. If I could get new drums for my 51 1 Ton, I would be jumping for joy! | | |
#48266 07/27/2005 10:16 PM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Saw some at Chevs of the 40s. | | |
#48267 07/27/2005 11:33 PM | Joined: Jan 2005 Posts: 19 Junior Member | | Junior Member Joined: Jan 2005 Posts: 19 | Unfortunately, Carter's doesn't have them. They have 1/2 ton drums for lots of years. They also have 3/4 ton drums for 53-59.
Chev of the 40s seems to have 6 lug drums. I will call them but am not hopeful.
Still searching. | | |
#48268 07/28/2005 3:21 AM | Joined: Mar 2001 Posts: 629 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 629 | what is the difference between the 41-46 and the "newer" AD trucks. I thought the front ends were pretty much the same well into the 50's?
Tim Sheridan 1947 First Series Chevy 1/2-Ton"Liberty Series" - "Art Deco" - Whatever you'd like to call it. In the Gallery | | |
#48269 07/28/2005 4:43 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Tim - huck style brakes ended in 52 - 53 to sometime in the 60's the drums are the same w/ the bendix brakes - they all have similar 'straight' axles
Bill | | |
#48270 07/31/2005 2:10 PM | Joined: Mar 2001 Posts: 629 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 629 | That's what I thought Bill.
Thanks Tim
