0 members (), 132 guests, and 2 robots.
Topics128,157
Posts1,056,876
Members48,458
Apprentice
Apprentice
I have a 57 Burb with the old vacuum wipers. As you probably know, they stink. However, I love the action where they both wipe to the center at the same time. So how do I go electric and not change my action, linkage and all of that stuff? Did the electric drive wipers of the 55-59 Chevys have the outside to inside sweep like that, or did they sweep in the same direction? Can I just buy a conversion for them? If so, where, what kit or company, and how much? Do I just need an electric motor of that era? Help me out, I'm truly lost. Bongo
Bongo,
You should be able to swap out the vacume motor for an electric replacement and not change any of your linkage or wiper travel geometry.
check Classic Parts that is where i got mine for my 52
1952 Chevy Shortbed
Photos in Photobucket
could also add a dual action fuel pump and increase the efficiency of the wipers. i did and is better but still not great. i also use rain-x which also helps. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Ron,
Yes I use rain-x it does help BUNCHES on the flat glass unless it is a downpour, most times i dont use my wipers.
Tim
1952 Chevy Shortbed
Electric wipers were an option so you should be able to find an original motor. It would mount in the same location and use the same cable type switch. 55-57 are the same, 58-59 are somewhat different and use an electrical switch.
Fred
These optional electric motors for the 55-57 come up on eBay quite a bit. Sometimes they come up locally, too. You shouldn't have much trouble finding one.
I have one on my 55 2nd. They are noisy.
Another thing you can do is add a vacumn canister in your line between manifold and wiper motor. This helps to keep your wipers moving when you slow down or idle. These canisters are usually plastic black balls and about the size of a tennis ball. They are found in later model cars. Easily found at the salvage yards.
Best of luck
Dennis
Send it to the Wiperman for a rebuild. It will work better than new. There's a link to his site in the "links" section,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
