| | | Forums66 Topics128,014 Posts1,055,333 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | Hey guys and gals, I just installed a new upper steering column bearing. I have a snap-on steering wheel puller that was just too big for the old 1941 steering wheel. The bolt holes to install the tool where just too close together and the puller could not be installed. The old guy mechanics use to take 2 hammers and remove the steering wheel by loostening the nut. Unscrewing it to the top of the steering shaft (flust with the top) and then with thier knees apply pressure to the underside of the steering while at the same time puttung one hammer on the nut and shaft and then hitting it with the other hammer. This will work, buuuuut you can screw up you shaft and/or nut. Here is what I did. I took off the generator adjusting bracket (the on with the long slot). Then I used 2 bolts and flat washers through the bracket into the steering wheel bolt holes. Then I used a bolt flat washer and nut as the puller center bolt. I also used a small piece of flat bar to put on top of the nut and shaft for protection. It worked like a charm.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Glad you found a way. I use a generic puller with "J" bolts through the puller & around the steering wheel arms at the base. A good bit of tension & a light tap with a hammer on the end of the puller if necessary (not normally necessary) and off she pops. When my knees didn't complain so much I used the knee & hammer method exclusively. Didn't require much of a blow so never screwed up a shaft or nut.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I had to pull a wheel to get a cab off, and didn't have a puller, so I made one, then I get to taking the wheel off and it about falls off once I remove the nut, didn't even get to use my fancy puller  Made it from a 1/2 x 3/4 bar a couple inches long. Drilled two holes the right distance and size to bolt to the hub, and in the center between the two drilled a 1/2" hole and welded a 1/2" fine thread nut over it, add a bolt, wrench, and a hammer and it's a puller. Grigg | | | | | Joined: Jul 2005 Posts: 581 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 581 | Man, mine must be on there real good. I fabbed up about the same type of puller with a bar, two bolts to the wheel, and a center bolt on the shaft with some washers. I torqued the wrench with a small breaker bar and it won't budge at all. Even tried a short chain bolted to the fabbed bar and attached to a 10lb weight thinking the momentum of the weight might get it to budge, nothing. Any other thoughts? | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Did you try Tiny's method. I've had some very hard to get off and usually, tension with the puller, someone sitting in the seat with knees up against steering wheel real hard and then a big whack with the hammer and it would pop up and off......be sure to run the nut down on the shaft till its even so that you don't ruin the threads.
..it might help to soak it overnight with some Kroil. Let us know how you make out. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Yep, if it's being stubborn whacking the center bolt on the puller with a hammer is the trick. Apply constant upward pressure to the steering wheel (as if it were coming off) while you whack the puller. | | | | | Joined: Jul 2005 Posts: 581 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 581 | Thanks for the replies, I shot some pb blaster on it and tried it the next day. It walked right off. | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Leave the nut on as you pull on the wheel and someone taps with a hammer. Your teeth will love ya. Don't ask me how I know Dan | | |
