1 members (Hotrod Lincoln), 79 guests, and 0 robots.
Topics128,080
Posts1,055,951
Members48,430
#476515 11/29/2008 8:18 PM
I need to replace the passenger side door lock on my '49 1/2-ton, but I'm having trouble removing it. How is this done? The latch mechanism has been removed, so the only thing left is the cylinder lock where you insert the key. I'm stumped.
headscratch
Im not sure on yours norcal49er but on most of the earlier locks they were held in place with a "clip" that slides in around the lock. I has some "bow" in it to keep tension on the lock. Look in the edge of the door to see if you see a slim/thin clip that has sort of a lip on it that you can get a hold of and pull out. I'm not sure but I have seen many locks held in place this way.
If the weatherstripping is still there, it's hiding the clip... oh, and it might be VERY difficult to remove so be prepared to have your patience put to the test.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
Found it! I slid the clip and the lock popped right out. Thanks!
