| | | Forums66 Topics128,021 Posts1,055,349 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 98 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 98 | My '41 1/2 ton has a '54 235 engine. The fuel pump appears to be from the 41-47 series. It smells of and has evidence of old gas in it so I'm assuming it worked for some prior owner. Does it matter that it's from an older truck series? | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | If it had gas left in it for a long time it may not work any longer. If it's working it should be OK but I would change it to be on the safe side. If the diaphragm is weak you could end up walking. I believe 37 through 51 all used the same pump configuration as for how it mounts to the engine and the pump lever shape.
| | | | | Joined: Nov 2007 Posts: 98 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 98 | Given the appearance of its insides, I'm definitely going to get a rebuild kit. Thanks. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The 1937-1955-1st single-action fuel pumps were/are interchangeable.
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | auto zone has a dual action fuel pump and also the original type.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
