3 members (Wayne67vert, Otto Skorzeny, stlcardinalsguy), 69 guests, and 2 robots.
Topics128,029
Posts1,055,417
Members48,422
#474511 11/23/2008 3:12 PM
My '41 1/2 ton has a '54 235 engine. The fuel pump appears to be from the 41-47 series. It smells of and has evidence of old gas in it so I'm assuming it worked for some prior owner. Does it matter that it's from an older truck series?
watsjoe #474519 11/23/2008 4:03 PM
Ex Hall Monitor
Ex Hall Monitor
If it had gas left in it for a long time it may not work any longer. If it's working it should be OK but I would change it to be on the safe side. If the diaphragm is weak you could end up walking. I believe 37 through 51 all used the same pump configuration as for how it mounts to the engine and the pump lever shape.
Tiny #474523 11/23/2008 4:14 PM
Given the appearance of its insides, I'm definitely going to get a rebuild kit. Thanks.
watsjoe #474537 11/23/2008 5:31 PM
The 1937-1955-1st single-action fuel pumps were/are interchangeable.
tclederman #474601 11/23/2008 9:30 PM
auto zone has a dual action fuel pump and also the original type.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
