| | | Forums66 Topics128,080 Posts1,056,062 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2002 Posts: 99 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2002 Posts: 99 | I did search around for this answer so please forgive me if there is already another post about this, but do you need to use special paint to paint a (stock) radiator?
Neil 1955 Chevy 3200
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | We use to use a special paint at the CAT dealership I used to work at so we didn't clog the area between fins and so it would not peel. Here is the quote from Eastwood's site on why to use radiator paint.
Standard engine paints are too thick for radiator use because they can interfere with heat transfer and block air flow between the cooling fins. Also, standard paint tends to flake off radiator tanks. Radiator Black helps solve this problem. This acrylic enamel factory-finish (85% gloss) withstands 300 degree F., sprays on thick enough to cover completely, yet thin enough to not interfere with heat transfer. Great for heater cores and air conditioning condensers, too! Each 12 oz net wt. can covers 6 sq. ft., most radiators require 2 cans for full coverage. | | | | | Joined: Mar 2007 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2007 Posts: 64 | Eastwood Company has a special radiator paint (high gloss black) in spray cans. I've used it and was satisfied. Joe | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | I DITTO,, OO's reply I used the Estwood Radiator paint it woirks very nice. Tim | | |
