3 members (Jon G, 2-Ton, festerhairball), 175 guests, and 2 robots.
Topics128,108
Posts1,056,238
Members48,437
#473749 11/21/2008 3:28 PM
I did search around for this answer so please forgive me if there is already another post about this, but do you need to use special paint to paint a (stock) radiator?
Neil
1955 Chevy 3200
We use to use a special paint at the CAT dealership I used to work at so we didn't clog the area between fins and so it would not peel. Here is the quote from Eastwood's site on why to use radiator paint.
Standard engine paints are too thick for radiator use because they can interfere with heat transfer and block air flow between the cooling fins. Also, standard paint tends to flake off radiator tanks. Radiator Black helps solve this problem. This acrylic enamel factory-finish (85% gloss) withstands 300 degree F., sprays on thick enough to cover completely, yet thin enough to not interfere with heat transfer. Great for heater cores and air conditioning condensers, too! Each 12 oz net wt. can covers 6 sq. ft., most radiators require 2 cans for full coverage.
0
0 Offline
Eastwood Company has a special radiator paint (high gloss black) in spray cans. I've used it and was satisfied. Joe
I DITTO,, OO's reply I used the Estwood Radiator paint it woirks very nice.
Tim
1952 Chevy Shortbed
Photos in Photobucket
