7 members (jal12147, F100Ranger, NJC, Bruce 1954-4100, Bill Hanlon, Hotrod Lincoln, 1 invisible), 111 guests, and 4 robots.
Topics128,087
Posts1,056,338
Members48,442
My '50 3100 has never had any hood lace, so I ordered some and the clips. Does anybody have a picture of theirs...I can't find any posts and/or pictures about how it installs/fits. Any help would be appreciated.
Regards,
citizendick
What is hood lace? Is that what the vendors called the part(s) you bought? What vendor and part number(s)?
Are these the parts you are referring to?
http://www.classicparts.com/1947-54-Hood-to-Cowl-Seal/productinfo/38-111/
http://www.classicparts.com/1947-54-Hood-to-Cowl-Seal-Retainers/productinfo/38-155/
it lays on top/across the cowling under the back of the hood. If you look close you can probably see where the old stuff was. Unless they have been filled and painted you should be able to see the little holes where the clips screw down to hold the lace on the cowling. It goes across the top and down the side of the cowling. Hope this helps. Let us know.
Here it is also listed. Part# FP117
http://www.oldchevytrucks.biz/47_55/full.asp?page=47
Also use some weatherstrip adhesive, the clips alone aren't enough.
I think my question should have been: what exactly is the cowling?
Keith
If it were easy they'd have grade schoolers doing it!
perfect. Thanks.
Here's a PICTURE of where it goes. The arrows point to the screw holes for the clips.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
thanks. I'll assume I can install it without removing the hood...
yes you can....and should!!
How did you get the two out that are directly below the windshield wipers? I haven't replaced mine because of those. I could never get the right angle.
Chuck
Blue 50
1950 3100 w/57 235
Patrick’s Saginaw 4 speed and 3:55 rear end
use a good weather strip adhesive on the screws under the strip, B4 you screw them in for added water protection.
Jim & Caroline
In LMC catalog, pg. 21, 38-8940 Grill, lower support 1947-53 $169.95
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
