0 members (), 112 guests, and 3 robots.
Topics128,090
Posts1,056,380
Members48,442
#47144 07/02/2005 2:31 AM
Found two pinholes in my oil pan. Will hand held propane torches provide enough heat to braze the holes properly? Don't have a welder.
#47145 07/02/2005 5:02 AM
I wouldn't use an open flame on something that held petroleum products, unless you plan on removing it from the truck first. Then, if you remove it take it somewhere to be welded up right or just replace it with a known good one. Also, propane would only heat enough to solder with, you can't braze with it.
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#47146 07/02/2005 6:11 AM
if ya wanna do it yerself, clean the oil off well inside and out
#47147 07/02/2005 8:19 AM
Thanks for the replys. oil pan is off the truck. found the pin holes after cleaning all thesludge etc out of it had quite a bit in there that didn't come out when I drained the oil. I had brazed a little over 20 years ago using an acetolyne torch and wasn't sure about the propane hand held
#47148 07/02/2005 5:30 PM
V
V Offline
Brazing or mig welding would be the way to go.you can buy a special tip for your propane torch called a Turbo tip that will get hot enough to braze with small diameter rod but for the price of the tip you could have it brazed at a welding shop.
#47149 07/02/2005 6:32 PM
take it to a shop 5 bucks and its done
#47150 07/02/2005 7:54 PM
Tab Offline
Clean it very well then take it to a local radiator shop.
delete my account and pictures
#47151 07/02/2005 7:57 PM
Tab Offline
But..... You may want to just replace it. Are these rust holes?
#47152 07/03/2005 6:18 PM
JB weld!!! Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#47153 07/04/2005 3:12 AM
Well I went the JB Weld route since it's a holiday weekend. Put it back together this evening will see how things go in the morning when I dump the oil in and fire it up.Thanks for all your suggestions.
#47154 07/04/2005 5:25 AM
Tab Offline
Ya glued yer oil pan?! lol!!!!
#47155 07/04/2005 2:18 PM
Read the post on other thread How folks made out so figure I'd try it. Worst I'll have to start over and take it to a welding shop. best it will work.
#47156 07/04/2005 2:37 PM
Good stuff, I usually let the first coat dry real well, sand it smooth, clean, and put on another thin coat...Never had a problem with JB doing it's job..Good luck, Steve
